Volvo v70 2.5 170 hk vont start
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Have you checked to make sure your main ignition cable is plugged in near the left hand fender near the battery? If it gets unplugged you will not get any power to the rotor/buttons for a spark. I would trace backwards on the ignition cables like that. Are you sure you have a fully charged battery? Also, sometimes the key in the ignition can be problematic on this year...jiggle your key and see if anything changes. Do lights come on in the cabin- doe the gauges in the dash work?
