I'm looking the basic zimmermanns (non-drilled and non slotted = about $50.00) with ceramic akabono pads. is this a good combo or do I need drilled and slotted rotors? Your thought are appreciated. I'm tired of the black brake dust and would like to get rid of it.
I drive this car to work. I need brakes that work and great performance isn't necessary. I just need good performance.
98v70 zimmermann rotors and akabono ceramicpads - thoughts?
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Can't go wrong with the Zimmerman/Akebono combo. Used it many times myself. It will definitely reduce the brake dust and will stop the car just fine.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Sole reason I went with Akebono is (was) brake dust. Was tired to clean the wheels every two weeks. I don't remember when I put the Akebono things, perhaps 4-5 months ago. I haven't washed the wheels yet, and don't think I'll have to do it this year either
Not kidding, the brake dust has dissipated. They bite less than the OEM but no noise. I have no idea what brand my rotors are.
98v70dad
- Year and Model: 98 V70
- Has thanked: 1 time
Whats is your thought on drilled and slotted zimmermanns vs just plain zimmermanns? I don't think I need drilled and slotted but I know that ceramic pads create a lot of heat. Drilled and slotted significantly increases the cost. The basic zimmermanns aren't that expensive. I am doing all 4 wheels.E Showell wrote:Can't go wrong with the Zimmerman/Akebono combo. Used it many times myself. It will definitely reduce the brake dust and will stop the car just fine.
- E Showell
Basic Zimmerman's will be fine.
'95 855 auto (sold)
'95 855 auto (sold)
kaneelschep
- Year and Model: '96 850 2liter t5
If you often brake hard from high speeds, you are a lot better off with drilled or slotted since they will warp otherwise.
If it is just for that little more stopping power with normal speeds, the normal ones will be fine.
1337
- Year and Model: '18 VW Golf 1.8T 5MT
I have basic Zimmerman rotors with OEM Genuine Volvo pads on all 4 corners. I like the setup a lot. No problems with fade when driving hard. The coating on the non-brake-pad part of the rotor has prevented rust.
The OEM pads can be a bit dusty... though I've seen worse.
Current: 2018 VW Golf 1.8T Manual
Previous: 1998 V70 T5 Manual, Subaru BRZ, Mini, Miata, etc.
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
I'm installing basic Zimmerman's and Akebono's on my XC right now. That's my prefered combo. I like that the Zimmerman's come "Z" coated and don't start rusting right away.98v70dad wrote:Whats is your thought on drilled and slotted zimmermanns vs just plain zimmermanns? I don't think I need drilled and slotted but I know that ceramic pads create a lot of heat. Drilled and slotted significantly increases the cost. The basic zimmermanns aren't that expensive. I am doing all 4 wheels.E Showell wrote:Can't go wrong with the Zimmerman/Akebono combo. Used it many times myself. It will definitely reduce the brake dust and will stop the car just fine.
I had the drilled/ slotted ones on my 850 and didn't like them that much. They lasted very long but made an annoying hissing sound when braking. That's only bothersome when you drive with the windows down.
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- 831 Views
Last post by 850 LPT
- 13 Replies
- 4111 Views
- 654 Views
Last post by 98v70dad
- 914 Views
Last post by sleddriver
- 870 Views
