Oil Thermostat Leaking Topic is solved
pfabs
Year and Model: 1998 S70 T5
Post by pfabs »
Hi guys , new to the Volvo World. Just got me a 98 S70 T5 originally from canada with a fair share of its issues. first and foremost being the leaking oil thermostat inlet hose.
Now last week i replaced the rdiator and all of the oil line hoses but opted to use generic o rings instead of OEM for the hoses that go into the oil Thermostat, now 1000 miles later its leaking oil. :oops:
I did have a fair amount of corrosion in the housing but as you all know, those arent made anymore so its not like i can replace that too easily.Going to redo the job this weekend with oem o rings, looking for a little insight on whether or not i should take any extra steps to make sure those hoses seal correctly in the housing or how to properly clean out the corrosion.
Any help would be awesome !
Has thanked: 2197 times
Been thanked: 1851 times
The dealer replaced the 'O' rings on my car twice and then told me it was the pipes that were the problem. I bought the pipes, but when I went to replace them, I found the 'O' rings had been nicked on fitting and hence the leaking.
I ended up removing the whole housing and took it onto my workbench and found old baked on hard oil from a previous leak had not been cleaned off so when the new 'O' ring was fitted it was torn going over the crusty oil.
The oil pipes were fine and I could have re-used them, but I ended up fitting the new ones as I already had everything in bits.
I used a metal scraper to carefully (and I stress carefully) remove the hardened deposits, maybe soaking in de-greaser overnight may work also.
If I recall removing the hosing was tricky as it used Torx headed bolts that were very reluctant to come out. Fitting the housing back on was a little fiddly to keep the gasket in place.
pfabs
Post by pfabs »
ok Neil, so getting that housing clean as can be is the #1 thing ? or else ill just nick the o rings again ? have you had any other leaks since your repair ?
Peter
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Use Volvo Green O-rings.
Flip the retaining plate around for better squeeze on the O-rings.
I posted photos in forum.
pfabs
Post by pfabs »
Where exactly did you post those ? and yeah im getting volvo green orings tomorrow from the stealership.
That is it basically, and add cn90's info to your plans.
Post by cn90 »
pfabs wrote:Where exactly did you post those ? and yeah im getting volvo green orings tomorrow from the stealership.
See the thread below, I mentioned the trick about flipping the plate around.
Make sure you have new Torx bolts.
I did this (flipping the plate around 2.5 years ago), zero leak as of today:
https://www.matthewsvolvosite.com/forums ... 7&start=40
pfabs
Post by pfabs »
thank you ! cn90. local dealer doesn't have new bolts in stock, this something i can get off the shelf ?
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
If the old bolt heads are not stripped out and the bolts not corroded, it's OK to not replace them. I never have.
I totally agree with erik on this. This is not a high stress part, so provided you can get them out without damaging them, then re-use.
I am glad cn90 put the info on about reversing the retaining bar, as I had forgotten about that.
I planned well ahead when I did this and replaces the bolts, gasket and 'O' rings as I hate doing work twice over. As it turned out the bolts were fine and I just straightened the retainer and re-used it if I remember correctly. I probably might have the other parts if I knew where to find them (no need for them as 99+ cars have a different system).
