Hello.
I was removing the door stop from the passenger door as it was clunking badly when being opened. I noticed that the weld in the pillar gave up and was loose and would need to be welded back on again. Thing is though I accidentally knocked it off and now it's somewhere inside the car... check the pic to see what I mean. Does anyone know what I need to remove to get access inside there?
Lost part of the door stop
- Been thanked: 504 times
Yes, you need to remove the trim panel to access the inside.
Then weld a new piece of metal to hold the new "door brake" in place.
This happens when you park the car "nose down" on a slope, then a strong wind blows the door as you enter the car, ripping the part that holds the door brake.
Tons of photos in forum.
PS: Do a google search using key words volvo door brake welding.
- 1999 Views
Last post by PeteB
- 4846 Views
Last post by Amk20155
- 1985 Views
Last post by jonesg
- 778 Views
Last post by Chuck W
- 250 Views
Last post by volvolugnut
