1998 S70 steering rack types
shegarty
- Year and Model: 1998
- Has thanked: 12 times
- Been thanked: 8 times
Hi all - I have noticed that I need to replace inner & outer tie rods as well as struts/seats as the front end of my 98 S70 is getting a bit noisy. However, I am unsure of how to determine which steering rack I have to make sure I get the right inner rods. Any help? TIA
98 S70 T5 SE 298k km (daily)
87 740T sedan (current project)
previous - 90 745T; 94 855 T5
PS78
- Year and Model: 2000 S70
- Has thanked: 2 times
- Been thanked: 3 times
Inside the engine compartment on the driver side on the inner fender there should be a product ID plate. On the right side column follow it down to the last series of numbers. The last number in that sequence should be a 4 or 5. If it is a different number or not present, you will have to visually check the rack body or inner boots for a manufactures mark to identify. Hope this helps.
Always first off the line, while all the cool people are still staring at their phones.
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
The number that ends with a 4 or 5 is supposed to be an 8 character alphanumeric. Both my 98s, (S and V)are early production and only have seven characters. This is also supposed to indicate a TRW rack. If there is doubt, or you suspect something may have been changed, visual inspection is best means.
Current Volvos:
- 1328 Views
Last post by erikv11
- 1195 Views
- 600 Views
Last post by Luigi74
- 870 Views
Last post by rspi
- 699 Views
Last post by DEMonte1997
