Hi, I'm new to Volvo world. I recently bought a 1997 850 T5. I had to replace the starter. No problem. My issue is inside the car. Here's what I got. 1. No low beams, but I do have high beams.
2. No turn signals, but I do have hazards. I do have parking lights and brake lights. 3. Speedometer is not working, but all other gauges are working. I have been browsing on here and have seen some similar issues that suggest the ignition switch. I have noticed that when you turn the key it doesn't seem to "click" by the different positions. Am I on to the right lead? I did notice under the driver's side dash 2 places that look like there are possibly missing relay switch or fuses. Any help will be greatly appreciated.
Thanks
Electrical issue, new to the Volvo world
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
try jiggling the ignition and see if slight variance will correct the situation. My 850 ignition has a dead spot that requires jiggling to correct when the key is in car, car runs fine but no lights, no signal, no speedo.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- Has thanked: 2203 times
+ 1 to the ignition switch. But other possibilities are:
1) ABS module failure (it affects the speedo but can affect other systems) - Perhaps contact Matty Moo at Mid-West ABS ( a long time resource on MVS).
2) Check the lighting relays, and earth contacts.
I am no electrical wiz, but ignition switch would be the first place to try and the 'wiggle' may give clues.
Prairiemaster1
- Year and Model: 1997 850T
Thanks, will do!
+2 on the ignition switch. I had to jiggle mine to get headlights and brake lights to work. Replaced the ignition switch, literally a 10 minute job, and no more jiggling. My main concern was no brake lights if I forgot to jiggle the key, plus I figured eventually jiggling would quit working.
