XC90 2WD Conversion Help - Disbaling Roll Stability Control (RSC) Topic is solved
zakmuh
Year and Model: 2003 XC90 D5
Has thanked: 6 times
Post by zakmuh »
Hi,
I'm looking into buying a 2003 model XC90 D5. This would be my second car and also a project car. I've read a couple of posts about this AWD issue with early XC90s. So I want to convert into a 2WD. Before I go about doing this conversion, I want to make sure this is doable. The first port of call, I checked with my insurance guys and they are okay with this modification.
With regards to the safety....when I remove the transfer box, I'll end up disbaling the differential electronic module (DEM) as I have to disconnect the Haldex, which then will disable the DSTC; this will not disable the ABS system. However...
1. What could happen to Active Yaw Control (AYC) and Roll Stability Control (RSC)?
2. Where are these two located? Are these two fitted into DEM?
I'd highly appreciate if anyone could help me out on this.
Cheers
doublebug
Year and Model: XC90 2007 D5
Been thanked: 7 times
Post by doublebug »
What needs to be done:
1. Change car configuration to switch off DEM and switch to STC.
2. Change software in the BCM to STC 2WD.
After that you can remove DEM and Yaw sensor.
Note that dealer won't help you in reprogramming because they are prohibited to make such changes.
If you have questions about Volvo firmware ask me. I may know an answer :)
zakmuh
Post by zakmuh »
Thanks mate.
As you've said the dealer won't change the software, I don't think I would be able to find a place?
doublebug
Post by doublebug »
I may help but you need to have DiCE.
zakmuh
Post by zakmuh »
Thanks for your offer mate, but I dont have a XC90 yet.
So can I conclude this thread saying 2WD conversion is not safe to do, unless the software is installed?
CHeers
doublebug
Post by doublebug »
I think so.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2854 times
Been thanked: 1332 times
Post by matthew1 »
It's doable, in the US at least, because many XC90s were FWD here... parts swap time.
Also -> Amazon link
zakmuh
Post by zakmuh »
Petrol (what you call in America is Gas) is expensive, so people buy small engined cars. So Volvo should've marketed those FWD ones back then in the UK as well.
