1994 940 sedan with turbo ac recharge problems
I bought an ac pro recharge canister, the connector will not fit on the pressure valve off the canister. Is that the low pressure port? Do I need an adapter valve? I called company and they said that is the valve and it should fit. It is a r134a system. HELP???
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
If it has a GM dryer with low pressure switch...one could remove low pressure switch, and fill this way with AC running and switch by-passed.jimmy57 wrote:On that year model the fill valve is a high side system...
Otherwise, suck it down, have a jug of R-134, with gauge lines purged, and then let liquid run into high side with engine off.
- 2323 Views
Last post by julesV
- 1260 Views
Last post by anothersullivan
- 645 Views
Last post by RickHaleParker
- 1250 Views
Last post by 93Regina
- 1249 Views
Last post by volvolugnut
