ABS/ Anti Skid Message??
toxtreme
- Year and Model: 00S80, 05XC90, 06S60
I have a 2006 S60 2.5T that I just started getting the ABS warning light on, and the Anti Skid service required message popping up. This goes on and off but seems to consistently pop up when I either put the car in reverse or apply the parking brake, any suggestions on what to look at first?
01_Nautic_V70
- Year and Model: 2008 XC90 V8
- Been thanked: 8 times
First, easiest thing to check is tire pressure and lug tightness. Any unusual noises happening?
without scanning the BCM and getting the code you'll find that it's a wild goose chase.
Could be power supply issue
wheel speed sensor issue
pump motor
solenoid failure
check the obvious things like wheel speed sensor wiring and the like, but if nothing stands out as a problem you'll need to get the errors out of the BCM with VIDA or a comparable aftermarket scanner.
pump motor
solenoid failure
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
One of the things to check with the wheel turned:
- 4913 Views
Last post by Treiku
- 650 Views
Last post by Ethan5150
- 873 Views
Last post by turbotim2
- 2147 Views
Last post by Stephen0523
- 2778 Views
Last post by blandis
