power steering leak,1994 850 wagon
loveMy850
Year and Model: 1994 850 WAGON
Has thanked: 97 times
Been thanked: 4 times
Post by loveMy850 »
Well today I pulled up on two flat bricks, I was able to clean all the grease off the line underneath,I didn't find anything,I pushed up on the line then looking under the hood where the hose meets the line is the leak,now where the hose goes into the line,there is probably an O ring,am I right??
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
So your power steering hose is leaking? Can you take pictures and post them?
85 GLH, 367 whp
00 Insight, 72 mpg
loveMy850
Post by loveMy850 »
Im not so sure how to post a pic,My post should have read,how do I change the hose,first time,Im not sure if its the pressure hose ,and do I have to ,well have you ever done this can you help me,Ill give you as much info as I can,just ask,ok.Thanks
loveMy850
Post by loveMy850 »
[quote="tryingbe"]So your power steering hose is leaking? Can you take pictures and post them?hello
tryingbe
Has thanked: 1 time
Post by tryingbe »
I don't live on the forum. You have to wait to get free help.
Can you email pictures? tryingbe at yahoo dot com
85 GLH, 367 whp
00 Insight, 72 mpg
loveMy850
Post by loveMy850 »
Wow I can try,Heck Im hoping Im replying to you correctly, I havent been on the forum in a while,these computers are like shooting pool,you dont use it you lose it, can you post the pics?
tryingbe
Has thanked: 1 time
Post by tryingbe »
Sure, I can post pics.
85 GLH, 367 whp
00 Insight, 72 mpg
loveMy850
Post by loveMy850 »
very pretty car,mines a tad older,looks like your on the road,I hope to get some good replys on how to fix this power steering leak..Have a safe journey...........
Has thanked: 1609 times
Been thanked: 4064 times
The high pressure line between the pump and rack is solid and doesn't use orings mid-line on my later model. I think your car is the same. You will need a new line or one from a pick and pull ( much cheaper)
