I have a 2006 XC 70 and recently noticed that the driver's side air vents are not blowing as cold of air as the passenger's side. This includes the center and end of dash vents. I have the dials for both sides set at "64". I checked with AC thermometer and the driver's side vents had a reading of 70-75 and the passenger side vents 60 (I believe 45-60 is normal?). The temperature was checked when car was parked in shade and readings monitored for about 5-7 seven minutes. The recirculate button is not on Would appreciate any feedback on what my issue might be. No sure if this is an electrical problem or duct issue? I am trying to get as much info before I have to take it to a garage for diagnosis.
Thanks
2006 XC 70 Climate Control AC Air Temperature Vents
- packetfire
- Year and Model: 2010 v50 2.4i
- Has thanked: 17 times
- Been thanked: 30 times
If you remove the panel on the right side of the driver's footwell, you will see a motor and linkage for the barn door that sends air to the driver's side. Behind the panel on the left side of the passenger footwell you will see three more of the same kind of motors and linkage that control the other aspects of things, such as directing air at the windshield, passengers, or floor, the motor that controls heat vs A/C, and the passenger side venting. Diagram attached
As you look, operate the controls for temp, and see how the mechanisms move. You may see that something on the drivers side is not the same as on the passenger side for the same motor, linkage, and barn-door. There is also a "calibration" of the motors, which is done with VIDA, and might be a good thing to attempt before approaching the stealership.
1982 240DL: Drove it 32 years and 1.5 million miles (sold, even still had mint leather!)
2001 v70 2.4T: The most expensive $1500 car I ever bought ("Volvo Turbo" - what an oxymoron!) (sold)
2004 v70: Far less fatally-flawed v70 - It served well (sold)
2010 v50: Smaller, slightly sportier wagon. Its got a spoiler, so I upgraded with sway bars!
- 1164 Views
Last post by Ou2mame
- 656 Views
Last post by comeaux54
- 28 Replies
- 25042 Views
Last post by firstv70volvo
- 4423 Views
Last post by jimmy57
- 17 Replies
- 1988 Views
Last post by MrAl
