Hi. In the flow chart for ETM, I got what I should out from pins 5 & 6 on ETM plug with the multi-meter.
Where it says to next try connecting one lead to the negative battery terminal and one lead to fuse #2, I assume that's with the fuse pulled out. Well, the right side of #2 fuse connector gives same as battery 12+ V, left side 1.46. Relay or crimp would you think.
Thanks,
Jim
ps. Engine management relay gets warm/hot fairly quickly. Should it?
Xemodex ETM flow chart
- 2769 Views
Last post by ChrisatXeMODeX
- 6848 Views
Last post by xHeart
- 4394 Views
- 2749 Views
Last post by Oka
- 8992 Views
Last post by volvolugnut
