Today I stopped at a long-established transmission repair shop to chat. We checked the trans fluid level and it was a little low. The shop manager offered to top it up. His mechanic came out with some pink slushy looking fluid and had a pint in before I could stop him. I asked what that stuff is and he said it's the old style fluid. This is an old car so that's what should be used.
I have been using Merc III ?? I think ?? which is what is mostly sold at auto supply stores. Is it going to harm anything to have the slushy looking stuff in there? Might I be advised to do a few drain and fills to get out as much as I can?
AT fluid compatibility question
- Has thanked: 17 times
- Been thanked: 35 times
It is the old stuff- Merc or Dexron III.... but "slushy stuff" worries me.
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
Today I called the local Volvo dealer. The service guys held a 5 minute conversation on this question and came back with "the transmission holds 20 (twenty!) quarts of fluid, type recommended is Dex III, but a little of the older style in there is not likely to make a difference. Life goes on.
tryingbe
- Year and Model: None
- Has thanked: 1 time
- Been thanked: 26 times
JimBee wrote:Today I called the local Volvo dealer. The service guys held a 5 minute conversation on this question and came back with "the transmission holds 20 (twenty!) quarts of fluid
NOPE! 8 qt only!!
Here's the owner manual.
http://volvo.custhelp.com/app/manuals/O ... om_id/1024
Automatic transmission fluid
Quality: ATF Dexron IIE/ III and Mercon
Capacity: 8 US qts. (7.6 liters)
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
JimBee
And that was from the Twin Cities' major Volvo dealer. I thought that sounded ridiculously high, but they insisted that was the number and I don't think they were teasing. Sheesh. Maybe the guy who came up with the number worked on Volvo tractors, then it might be more accurate.
I called the AT shop to ID the fluid they used and was told what they have is lighter pink than the store brands and will work with either Dex II or Dex III applications.
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
Hi,
20 quarts sounds pretty high. Mine (v70 1998) takes 8 quarts.
I suppose it is possible, as 5 gallons of liquid can be contained in a space very close to:
12 inches wide by 24 inches long by 4 inches high,
which would be a large rectangular pan size.
Alternately, 5 gallons of liquid would fit in a square pan 18 inches by 18 inchs by about 3.6 inches deep.
Just sounds like too much though compared to my vehicle which as i am told was derived from the 850.
- 3561 Views
Last post by precopster
- 24 Replies
- 8428 Views
Last post by erikv11
- 814 Views
- 15 Replies
- 5734 Views
Last post by jreed
- 1072 Views
Last post by rspi
