A/C Belt replacement 2007 3.2 engine 140k
vmaxmike
Year and Model: 2007 XC90 3.2 190k
Post by vmaxmike »
Can someone point me to where this slightly complex procedure might be covered here? Just want to see how to deal with separating the PS pump from the pulley as well as getting the compressor out of the way to get belt off to replace it. Thanks
vmaxmike
Post by vmaxmike »
Update: Found access to the online Volvo Workshop manual on this model which provided a color coded pictorial of what to remove and in what order so I was able to complete this 4+ hour job successfully. The biggest challenge was clearing the PS pump which requires a little T25 torx bit to remove 2 screws to separate off the the water pump assembly.
