Sounds like a vacuum leak. Braking hard uses up the vacuum so you put extra air into the engine which it doesn't like.
It's a drag but you have to check all the hoses and find the leaks and replace hoses
Throttle issues
- Been thanked: 4068 times
The idle air control valve (IAC) hose is often reported having a split
There is also an elbow on the vacuum port under the intake manifold , right side of car, near the thermostat and radiator hose
- Has thanked: 17 times
- Been thanked: 35 times
As abscate mentioned, you have to find that leak...if you don't find it in the lines he mentioned, follow the larger hose (most likely hardened) under the battery and on towards the driver's side under the windshield...there is a junction too along that line- closer to the left fender if my memory serves me right where two lines join together with a plastic connector. On mine, once upon a time, the plastic connector was broken. If still nothing, then I would suspect the brake vacuum pump itself which is not holding a seal.
- 928 Views
Last post by agloy63
- 2055 Views
Last post by mp5802
- 1837 Views
Last post by RickHaleParker
- 172 Views
- 11 Replies
- 2575 Views
Last post by dimataeus
