windshield rubber strips
adrian22
- Year and Model: s60 2006
On either side of the windshield are two plastic trim pieces that are painted the color of the car. They are held in place by plastic clips which I bought from IPD. Along these are some black rubber pieces that go from the roof to the bottom corner of the windshield. They appear to be a drainage channel. These rubber pieces are what I am looking for. Mine are dry rotted and falling apart. Does anyone know what these are called, the part number, or where I can find them?
adrian22
- Has thanked: 17 times
- Been thanked: 35 times
Others have posted about this before...they are called the Drip Molding- ours look fine on our V70 but it is garaged all the time it's not in use. My son's S60 is starting to show signs of the dry rot but it can wait for now. I have a friend whose are totally gone from dry rotting and so he pulled the remainder of the nubs that were left off- they don't look good in my opinion but he lives with it. The problem is that you can't buy those rubber pieces on their own. They come attached to the painted pieces. You can buy the whole piece from some (many have discontinued them) on-line vendors but those who have bought them have complained that they often come to them bent because they are so long and the have a tendency to be tossed around during shipment. Also, they are not cheap (as you can imagine). Getting them from a junked car is also typically not an option as those are usually dry rotted too. Sorry for the bad news but you could try buying them on line and chancing them getting to you unimpaired. If they are damaged in transit, the seller should refund you or exchange them in my opinion. Another option is to buy them from the dealer then you know they are going to come to you in good shape but then you certainly will pay a premium. I believe someone over on Swedespeed was doing something different by building up the rubber with some type of liquid rubber compound on the painted pieces on his car but I did not continue to follow his progression to see if he was successful or not.
That said, you do not say which model year or car this is for...V, XC 70 or S60? Here is a link to the retailer who I found had the most reasonable price on these: http://www.tascaparts.com/auto-parts/20 ... -roof-scat The item you are after is #6 in the diagram.
Search for your specific car on the Tasca website and look under Body and then Exterior and then Roof. There is a difference between especially the V/XC70 and the S60 mostly because the wagons typically came with Eurorails on the roof while the sedans didn't. Also, there could be slight variations between model years too. I personally don't know if you could for instance buy one that is for the S60 (long to the rear windshield) and then clip it at where the Eurorails start on an V70 or not. The color of your car's specific paint are listed with different part numbers.
Good luck with this and let us know what you decided to do.
adrian22
thanks for kind advice
The car is xc70 2005
The tescaparts have it listed but dont have it in stock but I managed to get a rubber molding 1/2 diameter that will fit with some silicon calking
adrian22
JRL
- Year and Model: Several
- Been thanked: 16 times
How many times do I have to say this?
THEY ARE NOT MADE ANYMORE and haven't been for a couple of years.
If you can find one, in stock, at a dealer, terrific, but you cannot order them anymore
Jim, I would say that adrian22 did not know that or he would not have posted.
Please refrain from yelling (CAPS) as if he knew, or as if I should have known that they are no longer made.
Unfortunately, many on-line vendors list them as "out of stock" rather than saying "no longer available."
-MIJ
-MIJ
Archer
- Year and Model: 2002 V70/S60 T5
- Been thanked: 5 times
Drip molding....I have a V70R and both of mine were cracked/rotted. I peeled them off the plastic molding and also removed the plastic piece (have rails, so the windshield segment came off easily enough) I went to a local self-serve salvage yard and found two decent rubber strips off an S80 that were the same, more or less. Surprised I found such good ones because it appears that these rubber strips all have the same fate - to deteriorate. I believe the "S" series are compatible. Anyhow, cleaned off the old rough glue bits from the rubber strips and applied contact cement to both pieces (rubber strip & plastic molding segment) masked off the painted area accordingly and put the pieces together - worked well. Also bought new clips and windshield corner trim fro IPD. Bummer that this part is discontinued, it would be nice to have a new back-up waiting.
- 2236 Views
Last post by rnelson1020
- 12 Replies
- 3486 Views
Last post by 98v70dad
- 15 Replies
- 9785 Views
Last post by kaneelschep
- 2319 Views
- 1264 Views
Last post by JimBee
