2004 S80 T6 ATF
jennings C70
- Year and Model: 2004 S80 T6
when should the transmission fluid be changed and with what type of fluid
- June
- Has thanked: 523 times
- Been thanked: 261 times
My sister's 2005 S80 T6 transmission got destroyed several months back by her mechanic who put multi vehicle atf in her transmission during a routine service. It did not make it home. To prove a point I had mine done with Dextron III I bought at Walmart which was labeled Dextron III and my 2004 S80 T6 was just fine. While the car was in Osteen Volvo last month I had the Volvo Synthetic fluid flush performed. My transmission shifts smoother with the Volvo Synthetic. The first service which I watched personally the pan come off and new filter installed by her mechanic cost me $200 and my Volvo dealer charged $250 which flushed all the fluid. My S80 T6 has always been serviced by a Volvo dealer except for the first transmission service two months ago at 112,xxx miles and flush at 113,xxx by volvo. Until then the factory fluid was still in place with no problems. So if you are thinking about changing the fluid it takes Dextron III and be aware you may burn the transmission up if you deviate to multiple vehicle label fluid. I learned that our cars use a General Motors transmission and now that I know that I will change the fluid every 3 years or 36 thousand miles like my 1986 Buick Park Avenue service schedule recommended for that car and that 1990 Buick Reatta I owned new back then. Volvo says never change the fluid but Volvo didn't make the transmission. I can tell you that heat was both Buick's enemy and both cars would have burned fluid by changing time. I live in Florida and drive in bad traffic here. The original Volvo fluid still looked good and had no burnt smell after 12 years and 112,xxx miles. Good luck! June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- 11 Replies
- 11696 Views
Last post by STSCowboy
- 3246 Views
Last post by June
- 735 Views
Last post by Synergychaz
- 19 Replies
- 5754 Views
Last post by MoVolvos
- 3025 Views
Last post by boksalg
