Yesterday afternoon, I put in the new tensioner roller and the tensioner. No, I didn't pull the pin! I just couldn't get the Tbelt under the water pump and over the roller. Nothing budged. So I took off the tensioner. The belt went on real easy.
This morning I verified all of the timing marks. Now I cannot get the tensioner into position! The top of the tensioner barrel is touching the bottom of the roller and I cannot pull up the tensioner by hand any more that it already is. I need approximately 3/4" lift to get the tensioner to sit properly.
Stuck!
The belt is routed from the crank, roller, intake cam, exhaust cam, water pump, over the tensioner roller. No slack to the right or between the cams.
What am I doing wrong? This is supposed to be a cake walk. BTW, the belt is the same length as the old one - Conti.
1995 855T Tbelt swap woes
- Has thanked: 311 times
- Been thanked: 817 times
What about that PITA nub under the crank pulley, are you sure it is not hanging up the belt? Check to see that the timing belt notches are fully engaged down there under the crank pulley.
Klausc
- Year and Model: 1995 855 Turbo
- Has thanked: 5 times
- Been thanked: 15 times
That's IT!!! I initially poo poo'ed your suggestion, and then thought better and verify. Sure enough, that PITA is sucking up 3/4" of the belt.
Now the 'fun' part. Getting that belt on correctly.
Thanks for the bail out!!!
Klaus
Klausc
Erik,
I must have lucked out before or the V70 engine didn't have that nutbuster there. Now I understand why some mechanics remove the harmonic balancer. Sliding the belt in at a 90 degree angle and then turning it to fit is not the best method, but the only one I can think of.
Klaus
Yeah, I do the slide-and-turn method too, I agree not the greatest but it works. It is sometimes difficult to seat the belt in there, good to be on the lookout for the nub.
- 13 Replies
- 1686 Views
Last post by Sommerfeldt
- 2254 Views
Last post by henrysin44
- 17 Replies
- 6382 Views
- 847 Views
Last post by jreed
- 471 Views
Last post by Klausc
