1998 S70 (not driven in a year aftermath-Issues)
Nailedtothe417
Year and Model: 1998 S70
Post by Nailedtothe417 »
Life happened and I neglected my perfectly (then) working 1998 Volvo S70.
It now starts fine and slowly idles down at random and dies.
So far I have:
Installed a new battery.
Filled up the gas tank.
Changed the oil.
Replaced all spark plugs.
QMI Fuel & Induction Decarbonization Kit (EK10T)
Replaced a vacuum line to the intake.
Cleaned the Mass Air Flow Sensor.
All with no fix...Am I right in focusing on the throttle body,O2 sensors and fuel pump replay next?
Thank you all in advance.
Has thanked: 1609 times
Been thanked: 4063 times
I would check the fuel pressure at the rail while running.
Test the fuel pump relay with a simple jump wire
Throwing parts is expensive, it's cheaper and faster to diagnose faults than symptoms
Nailedtothe417
Thank you very much for the fast reply.
Would some quick checking on this fourm or YouTube lead me to the results on how to do those two procedures.
Would you suggest any certain way over another?
Semi-new to all this.
abscate wrote:I would check the fuel pressure at the rail while running.
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
Your fuel may be gunked up. Did you leave the car sitting with a full tank of gas? If not, that would speed up the process of the fuel getting stale.
Also, is it doing this without throwing any codes?
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
Nailedtothe417
Sadly, no it was sitting on empty but,I did fill up with the highest grade this week.
It does have lights on the dash but, I don't have a reader.
Willing to buy one if anyone has a recommendation.
850 LPT wrote:Your fuel may be gunked up. Did you leave the car sitting with a full tank of gas? If not, that would speed up the process of the fuel getting stale.
850 LPT
Post by 850 LPT »
I bought an older version of this years ago:
https://www.ipdusa.com/products/11431/1 ... -scan-tool
Works great, but it's not cheap. You can probably get something from Amazon way cheaper, but I'm sure others here may have recommendations as well.
Knowing the codes is essential for troubleshooting.
Dirk
dorvin
Year and Model: 1997 Volvo 850 T-5
Has thanked: 1 time
Been thanked: 4 times
Post by dorvin »
I would recommend an ELM327 adapter, and the Torque app for reading codes, if you have an Android phone. You can snag a bluetooth ELM327 for a few bucks off ebay, and that'll allow you to read stored codes.
Has thanked: 2196 times
Been thanked: 1850 times
That scanner is selling for under $80 US on several websites now with free shipping.
Nailedtothe417
Great. After work I'll review this thread again and place an order for one.
Thanks!
850 LPT wrote:I bought an older version of this years ago:
Dirk
Nailedtothe417
I picked up the MS300 model-It should be here Monday.
*fingers crossed*
