Disable Interior Lights
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
Hello there,
Any way to disable the interior lights that come on when the door is opened?
I dont need them and with modern flashlights i can see much better with a high powered LED light.
I dont want to permanently disable them however, so i don want to take the bulbs out for example.
On the old Hyundai i had, the only ceiling lamp had a three way switch where you could select one of:
1. On (always on, never shuts off)
2. Automatic (when the door is opened it comes on, when the door is closed it shuts off)
3. Off (never turns on unless you flip the switch manually again to 1 or 2 above).
Alternately, how hard is it to change one of the bulbs in one of the overhead interior lights?
I might be able to swap it out for a high powered white LED Luxeon or Cree Star which would easily provide MUCH better interior lighting when it is actually needed.
Thank you.
kippster41493
Year and Model: 1994 850
Post by kippster41493 »
Does you dome light look like this? If so the switch is in the center, the center position will turn them off completely.
dome light.jpg (8.27 KiB) Viewed 2791 times
1994 850 2.3 Turbo :D
1998 V70 GLT 2.5 Turbo :shock: - project now
1995 BMW 530i :)
1998 Eclipse GSR - 3.5" off the ground and headers
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
In my V70, I believe pushing the left side of the rocker switch disables the interior lights completely. Mind you, the footwell lights will always come on with the doors, regardless of whether the dome light switch is off.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
All of the interior bulbs are easy to get to, especially the overhead ones. Many people have switched over interior lighting to LEDs, e.g. https://www.matthewsvolvosite.com/forums ... =1&t=35000. LED availability has really improved since that thread was started (e.g. https://www.superbrightleds.com/) so you don't need to solder any more to do it, be sure to read some of the more recent posts. There are a lot of threads like that one if you try the search function.
MrAl
Post by MrAl »
Hi,
Thanks much, i'll look into those LED lights and the switch. Didnt think this one had a switch but if it is there i'll find it :-)
bmdubya1198
MrAl wrote:Hi,
Now that you mention it, I think some models didn't have the switch. Seems stupid, but I think I've seen it before.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
The switch is a standard feature. All trim lines have it.
The page you want:
http://new.volvocars.com/ownersdocs/199 ... 9.htm#pg51
The whole OM:
http://new.volvocars.com/ownersdocs/199 ... 70_000.htm
MrAl
Post by MrAl »
Hi,
Oh ok thanks for that link. I guess it is in the owners manual then.
I'll check next time i go out to the car. The switches are probably there i just didnt notice them yet because they are overhead.
bmdubya1198
The switches must be there.
Post by erikv11 »
Yes, the switches are definitely there.
