Volvo 850 wheel bearing socket size?
Has thanked: 2207 times
Been thanked: 1852 times
What size is the E-Torx socket required to remove the 4 socket bolts for the wheel bearing? I have 3/8" drive 14 and 16mm sizes but it almost fells like it is in-between.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
I haven't had to do a bearing yet but I am pretty certain it is E14. I know the tutorials say to pound the socket on, to make sure it seats well on the flares.
Good to know. I will be removing the whole hub assembly to repair the axle C/V boot and lower control arm so should be able to get this into the bench vice to attack it. I have has the bolts soaking in Deep Creep for a couple of weeks so hopefully that helps too!
Thanks,
Neil
Has thanked: 1610 times
Been thanked: 4071 times
I found this exact issue on my T5. I think I wrote up what socket I used to release it, too
It was in between Torx external bits as you note
I have linked most of my DIY threads to my maintenance log if you want to find it before I'm back online
I found your blog and the link to the E14/11mm 6 point socket note. Thanks again.
