Yesterday was a hot day in Providence, Rhode Island, and it's been hot for a while. Which apparently explains why, last evening, the rear-view mirror in my 1993 240 came unglued from the glass.
I've read up on the general principles of re-attaching this mirror, and I have some 3M adhesive in hand, but there is a twist: the mirror is connected to a wire, and I can't see how to safely disconnect the wire at either end. All of the instructions on how to re-attach this kind of mirror start with the mirror in one's hands, so that one can detach the "button" from the mirror, but with it dangling from a wire, this is nearly impossible.
I'd appreciate any tips from anyone who has had to tackle this before! Thanks in advance.
'93 240 Rearview mirror re-attachment
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
1989 Volvo 740 side mirror glass replacementprofrap wrote:rear-view mirror in my 1993 240 came unglued from the glass.
Viewer stated:
TheMaltodexter2 years ago
thank you! same system for my 240.
It's (somewhat) encouraging to know that I'm not the only one! But the link is about the side-mirror on a 740.
I have cleaned the glass, and am now going to see if I can get the "button" out of the mirror mount -- will have another look to see if the cord has any point at which I can disconnect it. If this all works, I'll post what I did!
I was able to get this done -- assuming the adhesive holds! Turns out the "button" is held in place not by a sprint, but by a set-screw that takes an Allen wrench -- it actually is much preferable, as when you re-attach the mirror to the button, you don't have to use any force. The wire also turned out to be connected to a mini-wire-harness in the base of the mirror, easily removed with a little tab. Fingers crossed that it's a permanent fix (I used 3M rearview mirror adhesive).
- 1629 Views
Last post by phils94850
- 982 Views
Last post by CoreyD
- 325 Views
Last post by waltgphd1
- 688 Views
- 1059 Views
Last post by Bankrupt
