Can someone help me with the torque specs on the Front Suspension for my 98 S70
Ball joint on to lower Alu control arm
Lower Alu control arm to frame
Ball joint into spindle
Sway bar links
Main axle nut
Strut
Passenger side axle ubolt that locks axle in place.
I have everything just finished, but instead of arm strong tight, I thought I might do it the right way.
In torque lbs if possible or not. :O)
Thank you!
Ken
Front Suspension Torque Specs 98 S70
- Been thanked: 504 times
This should help you.
Don't forget to "preload" the control arm before tightening it.
DIY: 1998 Volvo V70 Front Bilstein TC Strut Tips/Tricks
https://www.matthewsvolvosite.com/forums ... =1&t=28455
- 1898 Views
Last post by ThommyKent
- 15154 Views
Last post by alschnertz
- 5840 Views
Last post by Navservice
- 1727 Views
Last post by kosh_al
- 3546 Views
Last post by gibbi42
