c70 2004 trans flush
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
gpaqu25
Year and Model: 2004
Post by gpaqu25 »
So I did my trans flush today. I purchased the flush kit, and had it all hooked up. Started the car, And the fluid came out of the hose not the radiator. I ended up doing the 2+ gal flush from the hose. This hose was the one on the top driver side.
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
Hi,
I was told NOT to flush mine. Not sure why yet. Your trans still works ok?
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 28 times
Post by cuhfs »
C70 trans is the AW 55-50 model which volvo claims is a closed system. Same exact model trans is also used in other Import cars like toyota and also some domestics all say the fluid should be changed at a specified interval. I have 2 - 04 c70 that both had trans problems because prior owner did not service the trans. Also know others that had trans problem÷.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
gpaqu25
Post by gpaqu25 »
The car has 107,000, the old fluid was dark and smelly. I used mobile 3309, Took the car out after for a short test drive. seems ok.
cuhfs
Post by cuhfs »
1 of mine went bad at 96,000 the other at 120,000 so you never know. I will be changing my fluid very periodically and put an inline filter because the repairs which I did were not easy. Never want to have to do them again!
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
gpaqu25
Post by gpaqu25 »
is there a explanation of why the fluid came from the hose instead of the radiator ?
cuhfs
Post by cuhfs »
That car, that's the flow I assume. I believe I had the same result the one time I did the hose method from IPD. Now I prefer the.Robert DIY three 'drain and fills'
driving in between, and not the hose method. It introduces the new fluid slower and at intervals so it is less shock to the system IMHO.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
