I pulled my front struts and I am going to replace them. When I stand them (Volvo/Sachs old struts) vertically against the ground and push down the shaft it goes down (a little too easily). One comes back up slowly and the other doesn't come back up unless helped. So they are old and worn...but does this lack of rebound mean anything? Should a strut rebound?
And now relating to then new replacements: should the new pair of shocks (Koni STR.T) rebound/rise quickly and about at the same rate? One comes up fine (takes about 10 seconds) and the other goes up very slowly about half-way and then stops.
Koni are lifetime warranty, but I don't want to even put them in the car if the slowly rebounding shaft on one of the two means one of them is defective. And I don't know whether this is a real test of anything. What do you think?
New Koni struts - does no rebound after compression mean defective?
- Has thanked: 2197 times
- Been thanked: 1850 times
I would suggest this is a question for Koni. The fact that both struts do not act in a similar manor would suggest one is not acting as it should. I had a similar problem with a pair of Bilstein HD's (although not new). I scrapped them and replaced with new after talking to a reseller for Bilstein.
Ringo
- Year and Model: 2006 70XC
- Has thanked: 33 times
Thanks, I am returning them to the place I bought them.
2006 XC70 2.5T auto (B5254T2) 125K 2nd owner
1999 V70 XC 2.4T auto (B5254T) 250K Trans failed 2018
1967 122S 2-door auto (B18B) 125K (ex-wife got it 1991)
rguzz
- Year and Model: 1996 850 turbo
- Been thanked: 25 times
Pump them repeatedly not just once or twice, after a few pumps you'll have a better idea how to compare one to the other. You may have done that already. I have set of KYB's one was weak out of the box, so new "bad ones"can happen.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Yep. that one was shot. But they are shot anyway at 100K miles. These Sachs don't leak and still rebound properly going over a pothole. Where they fail is they get stiff, and in cold weather is even stiffer to the point it feels like riding without suspension.Ringo wrote:I pulled my front struts and I am going to replace them. When I stand them (Volvo/Sachs old struts) vertically against the ground and push down the shaft it goes down (a little too easily). One comes back up slowly and the other doesn't come back up unless helped. So they are old and worn...but does this lack of rebound mean anything? Should a strut rebound?
They gave you a faulty item. They should rise quite quickly both at same speed in about 3-4 seconds. I'd even say 10 seconds is way too long, while the other is good for garbabage (or decoration given the nice color). Don't waste your time installing them, the car will be unbalanced to one side when changing lines, especially at highway speed.Ringo wrote:And now relating to then new replacements: should the new pair of shocks (Koni STR.T) rebound/rise quickly and about at the same rate? One comes up fine (takes about 10 seconds) and the other goes up very slowly about half-way and then stops.
Where did you get them from (seller)? Undoubtedly he is fishy.
- oragex
self reply button strikes again
- 1759 Views
Last post by aaronlife
- 1101 Views
Last post by dikidera
- 722 Views
Last post by oragex
- 3047 Views
Last post by shaker_chi
- 4976 Views
Last post by oragex
