c70 trans flush
gpaqu25
Year and Model: 2004
Post by gpaqu25 »
I did a flush on my C70 2004, And instead of the fluid coming out of the radiator , it came out of the hose that I took off. The top right hose. I did the 14 qt flush this way , draining 2 qts. at a time, and re-filling. Any thoughts????
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
This actually belongs in the P2 category forum but I see you posted elsewhere too and I have already moved that post to the correct location. One of the issues is that the C70 up to 2004 is very similar to the 850/S70's through 2000, but actually it's a whole lot like the P2's so the C70 is a bit confusing but from 2001 on the direction of flow of the fluid changed directions, that's why you had the surprise. At least, it looks like you didn't spill the fluid everywhere like some others have! If you did the flush in the way you describe, you did right...I hope you can feel a difference in the way she shifts now.
gpaqu25
Post by gpaqu25 »
Thanks ! Just about a pint spilled out all over, And yes I wasn't sure which form was for 2004 C70. I will look for the P2s form. It's a new car to me, and I wasn't sure if something was hooked up wrong.
