upgrade spark plug wires?
kippster41493
Year and Model: 1994 850
Post by kippster41493 »
I'm getting a pretty decent misfire with replaced when bought the car cap and rotor, recently done spark plugs, and old wires (not sure of brand.) I see a lot of people recommend the Bougicord brand, if for kicks and giggles I upgraded the ignition coil to the MSD would these wires stand up fine to that or should I go with a set of "performance" plug wires? just out of curiosity for now :)
1994 850 2.3 Turbo :D
1998 V70 GLT 2.5 Turbo :shock: - project now
1995 BMW 530i :)
1998 Eclipse GSR - 3.5" off the ground and headers
Ben850
Been thanked: 7 times
Post by Ben850 »
The only wires you want are original Bougicord.
They seem to be the only ones that do not cause issues.
Original Bosch cap and rotor.
MSD is ok, but unless you are at 300hp or above, the original Bosch is fine.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
kippster41493
Ok, was just a hypothetical that popped in my head from reading other threads and was curious. Thanks for the info!
1995 BMW 530i :)
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
The factory setup for 1993-1998 single ignition coil is very good:
- Spark Plug
- Bosch Cap/Rotor
- Bougicord
- Bosch Ignition Coil
I don't understand all these "upgrade" to better ignition cord, ignition coil.
These "upgrade" will not make the car run any faster or more powerful.
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
cn90 wrote:I don't understand all these "upgrade" to better ignition cord, ignition coil.
That's not strictly true... better spark can make a real difference, especially (like Ben850 also remarked) when the goal is 300 hp and up. While the Bougicords will easily handle it, an upgraded coil can deliver a better stability under those kinds of demands. But, again, +1 to Ben850's statement - there's no need for it unless the goal is high HPs.
- S
[Sold] '97 S70 T5
kippster41493
Which is understandable, it won't add a ton of power, but it will definitely be able to handle the 300+ HP Which I don't have now, will be in the future once the underbody parts/ chassis parts stop breaking :( Again this post was to pick peoples brains not start a war over stock/ aftermarket because everyone's preference is different on what they do to their cars :)
1995 BMW 530i :)
beigg
Year and Model: 850 97
Post by beigg »
Only reason to go to something 'better' or 'different' for a stock or lightly modified Volvo in this situation would be to address aesthetics imo.
ugh smh 850 Turbo fridge
Has thanked: 1610 times
Been thanked: 4068 times
kippster41493 wrote:Which is understandable, it won't add a ton of power, but it will definitely be able to handle the 300+ HP Which I don't have now, will be in the future once the underbody parts/ chassis parts stop breaking :( Again this post was to pick peoples brains not start a war over stock/ aftermarket because everyone's preference is different on what they do to their cars :)
The war will end quickly when performance/300 HP stuff moves to the Performance Forum.
:D :D :D
shaker_chi
Year and Model: 94 850, 98 S70T5 M
Has thanked: 3 times
Been thanked: 3 times
Post by shaker_chi »
I was having misfire issues with my 98 S70 T5 when under heavy load and it turns out I had a bad boot on one of my cables. I went with the 8mm IPD cables, installed Volvo spark plugs and replaced the cap and rotor with Bosch parts and haven't had a problem since. These cars are very picky when it comes to plugs and wires.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
shaker_chi wrote: ... These cars are very picky when it comes to plugs and wires.
True, true, true.
