1996 855T M56 problem? (Inner axle shaft failure) Topic is solved
the65dartguy1
Year and Model: 2001 S60 2.4T
Post by the65dartguy1 »
While driving my 1996 855T M56 today, it lost all power output from the transmission. It happened between 1st and 2nd upshift with no noticeable sounds or crunches. The car now acts like its stuck in neutral permanently and the gear selector doesn't seem to do anything. I can see the linkage is moving at the transmission However. So did this thing grenade internally? Anything I can look at first before removing the gearbox and throwing it down a ravine? The clutch, PP & bearing all have less than 500 miles on them.
Thanks for any advice!
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Make sure that the axle didn't pop out, particularly the left hand side.
the65dartguy1
It appears to be in there OK. I can't accurately measure but it looks like an 1/8th" clearance between the fat part of the inner axle and the trans..
Has thanked: 1610 times
Been thanked: 4065 times
Jack up the front two wheels and see whats spinning.
A new clutch job? Could be something has grenaded there - more likely than the trans, I think.
the65dartguy1
So it was a sheared axle inside the trans. Snapped off right at the spot for the retaining ring!
Anybody have a preferred axle supplier/brand?
And thanks for all of your help!
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
the65dartguy1 wrote:Anybody have a preferred axle supplier/brand?
This https://www.matthewsvolvosite.com/forums ... 27#p410227 seems to be the best of what is a group of poor choices. I haven't tried NAPA myself, but I've tried one of the bad choices.
Also -> Amazon link
kippster41493
Year and Model: 1994 850
Post by kippster41493 »
Carquest isn't bad, I've used them before in my V70 and never had issues with them.
1994 850 2.3 Turbo :D
1998 V70 GLT 2.5 Turbo :shock: - project now
1995 BMW 530i :)
1998 Eclipse GSR - 3.5" off the ground and headers
Ive got a left hand side one in my stores from when I ruined my original doing the FWB.
Do you need the car back on the road stat?
Ill donate it for karmic points if you are tight on budget, or sell cheap if you arent.
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
Is Raxles no longer recommended?
Post by Ozark Lee »
Raxles no longer rebuilds Volvo axles. He couldn't get good cores which is a shame, they were the absolute best.
