2008 XC70 ...found a loose rubber piece in my oil filter housing
So, I was doing a typical oil change that I've done numerous times before and I found loose rubber disc about 1/2 inch in diameter in the bottom of the oil filter housing. It looks like it was attached to a piece of spring steel that gets pushed down to close a small hole at the bottom of the filter housing when the filter gets tightend down. I've tried to find a replacement part online with no luck but I'm not even sure what it would be called. I'm hoping I don't have to replace the entire oil filter housing. Any input would be appreciated. Thanks
- Been thanked: 4071 times
That needs a picture desperately !
Have you tried the parts explosions at either Alldata or this one? Put your model and year in and look in engine lubrication.
http://www.volvopartswebstore.com
The only replacement part available is the entire filter housing. Since my original posting a Volvo tech has told me that it is a drain hole plug for draining the dirty oil when the filter is removed. I'm just going to find a used housing and swap out the part.
- 229 Views
Last post by kodzillaa
- 2119 Views
Last post by MrAl
- 591 Views
Last post by 850TurboTurtle
- 779 Views
- 1530 Views
Last post by alschnertz
