97 850 NA auto brake booster vacuum line
Has thanked: 2199 times
Been thanked: 1852 times
This vacuum line from the intake manifold to the brake booster is the original and brick hard and splitting when removed. Is there a reasonable option out there that can be used to replace it? I believe it may not be a metric diameter but imperial from something I read.
I need something that will not collapse under vacuum.
A second question is why is there a huge spring clamp on this pipe at the intake but not at the joint half way to the booster? Is it to prevent the weight of the pipe to cause it to fall off?
Thanks,
Volvo part # is #2524376
PS78
Year and Model: 2000 S70
Has thanked: 2 times
Been thanked: 3 times
Post by PS78 »
I used 3/8 Thermoid fuel line. Holding up great. Ace hardware had it in bulk which surprised me. $1.20 per ft. US made too.
Always first off the line, while all the cool people are still staring at their phones.
Thanks, I'll look into that at local parts stores.
sleddriver
Year and Model: 1998 V70 T5
Has thanked: 11 times
Been thanked: 13 times
Post by sleddriver »
I replaced part of mine using metric, red silicone tubing, rated for vacuum. The section between the IM & the plastic connector you refer to. Ran out of it and no longer available locally where I bought it. Mine is rock hard like yours. Probably leaking around the joints as well.
M1 10W-30 HM
