1998 S70 T5 All Dash Lights Flicker/Turn Off and On Randomly Topic is solved
SleeStak69
- Year and Model: 1998 S70 T5 5MT
Checked the fuse, looked fine, sprayed some Electrical Cleaner Spray on the fuse, didn't help. But I do think that there is a 95% chance that something is loose because if I push the brightness toggle up and keep my finger there, all the gauges work flawlessly until I let go, same with if I kind of shift/wiggle the whole button to the left and again hold it in that position. What should I do???
Pewter Silver Metalic 1998 S70 T5 5 Speed
- Been thanked: 4063 times
Replace the light switch rheostat with one from a pick n pull.
Looked for new one on FCP but couldn't find it. Dimmer or rheostat?
SleeStak69
Aren't the rheostat and the dimmer the same thing? I should replace that button? How do I get it out?
SleeStak69
http://tvwm.blogspot.com/2012/11/replac ... o.html?m=1 Looks like a piece of cake to me
Same thing. I tried searching both terms with no luck. Pull the part number of your old one and try that for a search term if you want to buy newSleeStak69 wrote:Aren't the rheostat and the dimmer the same thing? I should replace that button? How do I get it out?
SleeStak69
Same thing. I tried searching both terms with no luck. Pull the part number of your old one and try that for a search term if you want to buy new[/quote]
Thanks so much bro! Got a switch at the salvage yard and it works perfect now
- 16 Replies
- 6518 Views
- 1213 Views
Last post by regent
- 2077 Views
Last post by ferocity02
- 11 Replies
- 2251 Views
Last post by wizechatmgr
- 1422 Views
Last post by Abrown99
