Just changed pnp in a 2000 v70
Jaybar
Year and Model: 95,97 850
Post by Jaybar »
Swapped out PNP then ABS light on now brake light on dash on and odometer flat lined thinking someting with the plug?
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Could be- If you haven't buttoned her down completely yet, take it off- spray with a good cleaner (like a MAF cleaner) and use some dielectric grease in the fittings and work it off and on a few times and see if this clears things up. if not, then you've hit something- maybe even a fuse went. My luck has been that things go wrong in (at least) pairs with these cars and much of the time they seem completely unrelated.
Jaybar
Post by Jaybar »
Thanks did try no luck but my wife googled all the symptoms and it hopefully is the ABS module can get it at Midwest Abs for 99 plus core return
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
I highly recommend Midwest ABS but I would check with forum member Matty Moo first. He runs Midwest ABS and can likely tell you right away if your symptoms match those of a bad ABS module.
