Hey Guys and Dolls,
I have just taken my 1st dive into the Swedish pool of fun and boy I think I'm in deep on the learning curve. It's a pretty descent driver and reminds me of my exs Audi A4 Avant... smooth!! I could drive for days in cars like this! It'll probably be my Daily Driver until my son gets his license, then it'll be a great safe learner!!
I have owned VW/Audi's for the last 20+ years, so I get the Euro mentality, but I see I'm going to have to relearn a few things.... let me explain.
I got this car from a local Volvo enthusiast, so I have no doubt what he told me about the cars condition (new T-Belt, Seals, Cam Sensor, W Pump, PCV Service...) is totally accurate, but my perception of the noted issues was a bit askew.
There is a small oil leak somewhere between the cam sensor and the turbo that puffs a little smoke every once in a while. Like a drops worth on a hot manifold. No biggie I think to myself while I'm buying it. Simple valve cover gasket change, right? I get it home and while trying to figure out where the valve cover is.... What do you mean, they don't have valve cover gaskets? The valve cover is the cam blocks too?!?!? Who in their right mind does that?
So I power squirted the nasty built up on the turbo and hoses and it's all clean now. I can see the whisp of smoke rise up from somewhere between the heat shield and block, but I'm not limber enough or knowledgeable enough to know what/where to look in there without disassembling it all. I have an endoscope cam that I am going to break out and see if I can spot it, but again, I have no idea where to start.
I've searched pretty deeply and I've come up dry besides the typical Shaft Seal replacement threads... so what, besides Shaft Seals in the general area of the Cam Sensor/Turbo Compressor is going to weep oil on the exhaust manifold at idle? Any typical culprits to look at?
Thanks for the help and apologies for any silly, stupid questions I will eventually ask!
Cheers!
K "Newbie" S
My 1st Swede! 1998 v70 GLT - 201k - Steep Learning Curve!
- Botbasher
- Year and Model: 98 "R" & 03 T5 V70
- Been thanked: 4 times
Never become a pessimist. A pessimist is correct oftener than an optimist, but an optimist has more fun, and neither can stop the march of events.-Heinlein
We have met the enemy and he is us.-Pogo
If speed kills, do brakes give life??
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
Could be the oil feed line to the turbo, on mine (2004 V70) it goes in the top of the turbo. Check the hose coupler clamp, could be weeping and running down the hard line.
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
Hey! Welcome to MVS.
Taking the heat shield off would probably be a good first step. Oil leaks can travel weird pathways, so cleaning everything down is a smart move. The heat shield is easy to get off, but don't go for long drives without it...
Take it off, see if that gets you a clearer idea of where the smoke is coming from. Jonesg's suggestion is a good one, though the intake line rarely develops issues on these cars. It could be coming from a leak around the oil filler cap's gasket, or travel around from somewhere else.
Cam seals should last you a couple of decades if they were done right, but there's nothing wrong about checking around the areas to see if something's seeping. That goes for the PTC and the connections to it - those places will spray oil mist if they're not on correctly. Other than that, sounds like you've got yourself a nice ride.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
tryingbe
- Year and Model: None
- Has thanked: 1 time
- Been thanked: 26 times
If there is smoke coming out of the engine inside the engine bay, your PCV system needs to be changed out. You'll have to take off the intake manifold to get to it.
I also strong suggest you upgrade to a bigger PCV hose and drill the PTC to be bigger.
https://www.matthewsvolvosite.com/forums/vie ... =1&t=76504
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
Bingo...the rear camshaft seals will make a mess of the backside & rear firewall side of the engine. Been there, done that on the sled. Royal mess to clean up afterwards too.Botbasher wrote:Hey Guys and Dolls,There is a small oil leak somewhere between the cam sensor and the turbo that puffs a little smoke every once in a while. Like a drops worth on a hot manifold.
Fortunately, they're easy to replace and the job is straightforward....after you remove everything necessary to get to them!
Welcome to MVS!
I have the same year car and have owned mine since 11,000mi. She was assembled in Aug of 1997.
M1 10W-30 HM
M1 10W-30 HM
- kippster41493
- Year and Model: 1994 850
I've got the same car, the only "common" leak I had was the seal around the oil filler cap. It is designed to run the leaking oil over the cam cover and through a little weep hole that leads right over the heat shield over the turbo. If you have the vanity cover on top still, remove it and see if there is a bunch of oil on it, two major places to check. The oil cap seal is alright and the PCV hose isn't leaking oil out.
1994 850 2.3 Turbo
1998 V70 GLT 2.5 Turbo
- project now
1995 BMW 530i
1998 Eclipse GSR - 3.5" off the ground and headers
1995 BMW 530i
Another 1998 V70 GLT owner here.
As said above, check the cam seals and oil filler cap gasket first. If those check OK, the exhaust heat shields (its a three piece assembly) only have about 5 bolts that hold the whole thing on. It's fairly easy to remove, but take a picture of it installed to avoid frustration putting them back on.
101
1998 white V70 GLT 230K "Elsa"
1998 white S70 T5m 180K "Anna"
obayha
- Year and Model: V70 1999 Base
- Been thanked: 2 times
All the above said is great information to start with.
Where in the great state of NC do you live?
I am in Salisbury and am a shade tree/ driveway mech when needed.
Shane
Shane
1998 V70 T5 331,000
Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
- Has thanked: 316 times
- Been thanked: 531 times
It's definitely possible for oil leaking from the cam seals to travel to the turbo/exhaust manifold and create smoke. Check around the cam sensor and distributor cap for oil leaking. I guess if they're leaking bad enough, it could happen. I just replaced my cam seals today, very easy job.
- Botbasher
Hey There... Thanks for the warm welcomes and great info. I think I have narrowed it down a bit. I did the glove test and it's drawing a vacuum under ldle and light throttle, so the low hanging fruit already fell!
I found one location was the oil cooler lines. I have smooth hose clamps from work, so I think I can solve that one without any major issue. Cut the swage and clamp it. rest of the line looks good.
The messy one.... I think I bit off a bit more than I should have! I'm a little miffed as there was no way you couldn't notice the "leavings" if you drove this regularly! It was parked in the trees when I looked at it and picked it up. Wonder why? Guess he did the PCV a little too late, huh?
The other one appears to be a rear main seal. The whisp appears to be a drop that accumulated during the drive dripping off. It's loosing about a 1/8 cup of oil on simple errand drives (20ish miles). It gets onto the pass CV shaft, which slings it all around. The flywheel appears dry, but upon closer inspection, I can see its travels out the port at the bottom and dirt is accumulating up inside it, so it's coming down from there, not traveling across it.
After endo-scoping it all out, I am pretty sure it's not coming from the Cam Seals or anywhere north of the exhaust. There is a lot of oil "dirt" up there, but not a lot of wet oil.
This was going to be the kiddos learner, but that's going to have to wait now until this is completely resolved. Oh Joy!!! I can't trust him to brush his teeth, so there is no way I'm allowing him to forget to add oil!!
Shane, be careful what you offer... I'm out of my comfort zone and I just might show up with a seal and a case of Ciders or Adult Root Beers!!!
Any thoughts on further narrowing the diagnosis and solutions? Is there a "yep, that's it!" test for a rear main leak before pulling the trans? That's a lot of work to find out the a widget seal right behind the gizmo holder, but that acts a lot like a rear main seal leak!!
Thanks guys!
K "some buyers remorse" S
Thanks guys!
- 983 Views
Last post by Cees Klumper
- 1282 Views
Last post by mightyjak
- 1426 Views
Last post by malcolm2
- 704 Views
- 791 Views
Last post by Euroboy
