99 V70R front brake piston seized "out"
volare
Year and Model: 1999 V70R
Has thanked: 69 times
Been thanked: 6 times
Post by volare »
I'm gonna go ahead and say I'm pretty sure the caliper is trashed but can't hurt to ask.
The Falcon is my kid's DD and she neglected to inform me that the brakes had begun sounding like a garbage disposal choking on a fork; I discovered this when I had to drive it this week. New rotors and pads acquired and I set to work on the driver side, which was not without its own bugaboos and involved a breaker bar, a torch, and a lot of swearing.
So everything is apart, cleaned, etc. ready to go back together and I go to push the piston back with a c-clamp (using the remnant of the old pad)... nada. Thing will. not. budge. Can't say I'm surprised tbh.
Bleeder valve open just a hair to let fluid out to allow compression. Drippage but no movement of the piston.
Hit it with P'Blaster.
...I'm guessing I have to go find a pair of reman in the morning. I don't think these have enough life left in them to bother rebuilding, they've seen too many Massachusetts winters.
'99 V70R 180,299 SOLD to a good home!
'06 Baja
'77 Aspen
'99 Honda Rebel
~The Hooptie Herder~
JimBee
Has thanked: 33 times
Been thanked: 43 times
Post by JimBee »
O'Reilly Auto Parts might be your best bet. They warranty them for life and are competitively priced with other auto supply stores.
volare
Post by volare »
Irony there is, the kid we bought the thing from works at local O'Reilly. Autozone has one set in stock and one that's special order; ten dollar diff or so. Guess I'll have to see when I get up in the AM.
'06 Baja
'77 Aspen
'99 Honda Rebel
Has thanked: 2197 times
Been thanked: 1850 times
Looking at the condition of the end of the piston, it looks very toasty. The importance of having good brakes is obvious and exchange units are not too bad. FCP had some on clearance last week. I'd try removing the bleed nipple altogether and then try with a cloth over the hole to catch fluid see if it will collapse.
Just be glad it is not the rears on a 2000 ' R'. Rebuilds are all you may find and even those are like rocking horse poop to find.
volare
Post by volare »
scot850 wrote:The importance of having good brakes is obvious and exchange units are not too bad.
Exactly... Given it's The Teenager's car, makes me a LOT more antsy about making sure the brakes are good.
If it was my DD I'd be fine with dinking around with it some more, trying to get it to collapse etc. because if it crapped out again I'd know what was happening and it wouldn't be the first, second or third time I've had brakes malfunction.
Kid, not so much.
I have to get it back on the road asap. I'd be happy to order from FCP but I'm caught in the position of "need them NOW".
I haven't closely inspected the rears yet but I'm thinking to order those from them soon, before the dookie hits the fan again.
Jay
'06 Baja
'77 Aspen
'99 Honda Rebel
I hear you on the need it now part, but wise precaution on the rears in the future. Also replace the flexi hoses while you are at it either now or when you do the rears. Again FCP has ATE for the front for abut $10, not sure about the rears.
I've used re-manufactured unit and only had one issue with a bad seal but was replaced under warranty.
Has thanked: 1609 times
Been thanked: 4064 times
Well thats easier to find than unicorn poop at least.
I have Cardone rebuilds on both front and rear of the 1999 now - from FCP with no issues. The back worked so well, I disconnected the e-brake.
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
Hi Volare,
We do in fact have the calipers available for your car.
You can view them here : https://www.fcpeuro.com/products/volvo- ... ar-19b2568
Also, we offer a Lifetime Warranty on All of parts so your guaranteed for life.
You can learn more about our Lifetime Replacement here: https://www.fcpeuro.com/page/lifetime-guarantee
If you have any additional questions please feel free to ask, we're always happy to help.
Thanks,
Jason
volare
Post by volare »
Thanks Jason, I'm definitely going to order the rear brakes (rotors/calipers/pads) from you once I'm done wrestling with the fronts!
Jay
'06 Baja
'77 Aspen
'99 Honda Rebel
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
I wrote the Brake System overhaul a while back.
DIY: 1998 Volvo S70 GLT Parking Brake Tips/Tricks
https://www.matthewsvolvosite.com/forums ... =1&t=54614
NOTE:
- The issues of rubber hoses Front vs Rear. Use only ATE or FTE brand.
As a rule of thumbs, I replace my rubber hoses every 100K or so.
- Caliper: rebuild it yourself vs "new" caliper. If you are desperate, NAPA has rebuilt caliper, just make sure it has an ATE or Volvo logo on it.
Boston area (your area) has some NAPA stores.
