Did you know? 🤔
1999 S70 Replace Ignition Lock Cylinder and will not start
daveruckel
Year and Model: S70, 1999
Has thanked: 0
Been thanked: 0
United States of America
daveruckel
Post by daveruckel » Fri Jul 29, 2016 1:59 pm
We had our ignition lock cylinder lock up. The keys were kind of messed up anyway so we bought a new lock cylinder with keys and antenna ring. Had the battery disconnected for about a week waiting for the parts. When I installed it all seemed to go well then we went to start it. It will turnover but will not start. I replaced the main relay thinking that may have something to do with it.
Any help would be great. We do not have a key-fob so I cannot do the lock and unlock thing I have seen with the fob.
I have checked for engine codes and there are none.
What am I missing???
Please help save the day!!!
Dave R
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 44 times
Been thanked: 158 times
bmdubya1198
Re: 1999 S70 Replace Ignition Lock Cylinder and will not start
Post by bmdubya1198 » Fri Jul 29, 2016 2:32 pm
Since you have a 1999, your key is chipped. I believe it needs to be programmed to the ignition switch by the Volvo dealer if it's a new ignition.
If it's not programmed, the car won't start.
2000 V70R Venetian Red/Charcoal M56 Swapped 197k
2003 S60 2.4T Silver/Black 113k
2007 XC90 V8 AWD Sport Titanium Grey/Black 171k
1991 944 Turbo Dark Green/Beige 174k
1992 245 Base White/Beige 249k
2006 BMW 330i
1999 BMW 528i
2000 S70 GLT Mystic Silver/Taupe 253k
1993 944 Base Beige/Beige 221k
1998 V70 GLT Black/Beige 199k
1998 S90- Silver/Gray 207k
1995 850 GLT Tropic Green... crushed
2001 S60 2.4T Black/Black 230k
1988 744 Turbo M46 Beige Metallic/Beige 188k
Year and Model: Many Volvos
Has thanked: 4 times
Been thanked: 52 times
Post by Ozark Lee » Fri Jul 29, 2016 5:50 pm
^^This.
Any time a new key is introduced to the car, even if it is cut the same, the code from the key (I pray you saved the packaging) package has to be programmed into the system or the immobilizer won't let it run. The bummer is that it is pretty much a dealer only process and the car has to be physically at the dealership to get the programming done.
Mark60
Year and Model: 1999 s70 GLT
Has thanked: 2 times
Been thanked: 0
Mark60
Post by Mark60 » Tue Oct 08, 2019 4:26 pm
What would happen if I replaced the lock cylinder with one from a salvage yard
bmdubya1198
bmdubya1198
Post by bmdubya1198 » Tue Oct 08, 2019 6:22 pm
You would need the matching key to that lock cylinder of course, but that transponder wouldn't be compatible with the immobilizer. I'm not sure if the dealer can reprogram a used key, so you'll probably need a new one.
2006 BMW 330i
1999 BMW 528i
dj_v70
Year and Model: v70 2003
Has thanked: 5 times
Been thanked: 18 times
dj_v70
Post by dj_v70 » Wed Oct 09, 2019 5:58 am
Still have the old key? Cut out the new transponder chip out of key and use old one instead (most just tape them inside steering column).
Mark60
Been thanked: 0
Mark60
Post by Mark60 » Wed Oct 09, 2019 2:05 pm
I do have the old keys and fob.im waiting for the salvage lock and keys to show up.
Has thanked: 329 times
Been thanked: 1033 times
Trinidad & Tobago
Post by abscate » Thu Oct 10, 2019 4:50 am
You can buy another antenna ring from the junkyard, put the old key in it, and bury it under the dashboard , connected. You might have a two crank start process to get the car to run,but my S70 is in this mode.
Link To Volvo Glossary
Mark60
Been thanked: 0
Mark60
Post by Mark60 » Thu Oct 10, 2019 9:22 am
Thanks guys, I'll let you know how it goes when my used lock comes in
