I hopefully will have all the parts to re-assemble the PCV on the project 850 tomorrow. I have mentioned in another thread that a repair shop ripped the PO of by not replacing all the pipe, catch tank or any of the pipe clips.
It has been a long time since I did my 93 NA and I can't recall if the pipe on the LH end (nearest the crank pulley) of the intake (the small pipe from the flame trap area) should have a clamp on it or not. Naturally mine does not have one, but doesn't mean there shouldn't be one. I was sure there was as it is a PITA to get access to and fit.
Thanks,
97 850 NA PCV rebuild question
- Has thanked: 2205 times
- Has thanked: 311 times
- Been thanked: 817 times
Depends on what kind of hose you use. The factory pipe just has a rubber elbow, no clamp.
https://www.matthewsvolvosite.com/forums ... =1&t=65002
- Been thanked: 4069 times
I'm beginning to wonder if there is anything you guys don't know about these cars..
I still consider myself a forever apprentice compared to guys like erik, tryingbee, Lee and a few others on here. It is a continued learning curve!
I am convinced though that on out 93 850 GLT it had one of the those 3 pronged clamps on that pipe and it was a real devil to get to after re-installing the intake first. Easiest to do so before re-fitting the intake!
Interesting the pictures with the silicon hose show a cable tie holding it on!!
- 1353 Views
Last post by JIMMYCNOTES
- 13 Replies
- 1444 Views
Last post by amblerman
- 196 Views
Last post by fredt2
- 1659 Views
Last post by rspi
- 18 Replies
- 2995 Views
Last post by Clemens
