Hub centric rings for jaguar rims on a '98 S70 T5
SleeStak69
- Year and Model: 1998 S70 T5 5MT
I found a fantastic deal on some jag wheels but I need hub centric rings to fit them on! The jag is a center bore of 63.4mm and my Volvo has 65.1mm hub bores. The bolt pattern, size, everything else is perfect but I need those hub centric rings! Where do I find them!?! Please help!
Pewter Silver Metalic 1998 S70 T5 5 Speed
SleeStak69
Just called a tire shop and he said there literally no way I could put those rims on without it being unsafe
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
Yeah, cuz how i understand it the jag bore is too small. If they are?too big you can use centric rings. You'd have to find a machine shop who bores the nag rims to the Volvo center bore. Then there shouldn't be any concerns afaik.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
SleeStak69
Do you know how much a machine shop would charge and if it would be a perfect fit? I don't want to overpay but i also want to make sure it isn't a crappy ass fit. All four rims are for $220 anyways though so that's why I want them so bad
- 21 Replies
- 5617 Views
- 2391 Views
Last post by [email protected]
- 1908 Views
- 1892 Views
Last post by Mikaro07
- 1892 Views
