I have the problem child - a 2000 V70.
As many of you probably know, there is some difficulty knowing which fluid should be used in the power steering.
The manual says ATF, but from what I gather, this may be incorrect, and it might need some expensive green stuff instead.
I also understand that the two fluids are incompatible with each other, and it's important to know which one you have.
The prevailing advice appears to be that you should just check what color the existing fluid is and use whatever is already in the tank.
Unfortunately, when I wiped the little dipstick on a white sheet of paper, it was brown.
I have seen ATF go brown like this, but I also read that the green stuff goes brown as it ages.
Is there any other way of knowing which one I have?
For example, are the fluids incompatible because they are immiscible? Could I find out what fluid I have by siphoning a small quantity and seeing if it will mix with ATF?
2000 V70 Power Steering Fluid
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
Read up on what Harold has to say: http://howardsvolvos.webs.com/
M1 10W-30 HM
M1 10W-30 HM
PS78
- Year and Model: 2000 S70
- Has thanked: 2 times
- Been thanked: 3 times
Interesting read. Glad I went with pentosin. Some of the BMW and Audi guys have flushed and used Mobil synth atf and report good results. Pentosin is pricey but it's a good product, especially when outside temperatures plunge. A good way to save money on the purchase is to do pep boys 30% off code online and pick it up in the store that will save you about $5. One thing to note is if you need to top off and don't want to lay the money out for another full litre, Prestone European PS is $6 for a 12oz bottle at walmart and its the green stuff.sleddriver wrote:Read up on what Harold has to say: http://howardsvolvos.webs.com/
Always first off the line, while all the cool people are still staring at their phones.
- 30 Replies
- 27078 Views
- 6092 Views
Last post by EngineeringBloke
- 974 Views
Last post by FlyingVolvo
- 6645 Views
Last post by krenekj
- 4423 Views
Last post by amblerman
