A/c compressor only kicks on with bypassing main fuse in fuse box..
Cichyb
Year and Model: 1998
Post by Cichyb »
1998 s70 here quit blowing ac. Found 10 amp fuse blown and replaced, AND also the icecube (relay/fuse) -- black one
still nothing.
Bypassed the pressostat plugin (or low pressure) still nothing. have 12v going to plugin..
replaced the pressure switch down there by the light
still nothing
bypass the icecube relay in the fuse box and voila! I check pressure at about 45.psi
any ideas? ---maybe the pressostat? ecm?
thanks
Has thanked: 1610 times
Been thanked: 4065 times
It sounds like the AC clutch is pulling too much current. That probably means its at end of life. You can replace the clutch without replacing the AC compressor or breaking lines.
AC pressure measurements don't mean too much in diagnose unless you carefully control the conditions - If your AC was working well before, go for the clutch replacement - used is fine.
Set the gap first!!
Cichyb
Post by Cichyb »
would shimming it help?
Probably not. If its pulling too much current, there is an electrical fault. You could try measuring it by going to a 15 amp fuse as a temporary measure, or if you have a good ammeter, measuring the resistance of the clutch connections while they are disconnected from the car. The need to be greater than 2 Ohms or so to stop that fuse from blowing.
You are risking burning up your car bypassing the fuse or using the oversize one - Legal Department.
Cichyb
Post by Cichyb »
burning up car in terms of what? catching fire LOL or screwing the a/c system up?
Has thanked: 2200 times
Been thanked: 1852 times
The former!
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
Of course, catching the car on fire won't do the A/C any favors...
cichy1012
Year and Model: 1999
Has thanked: 1 time
Post by cichy1012 »
clutch replaced, still nothing. Anything else?
That means a wiring fault between the clutch and AC relay is pulling the current.
Download the wiring disgram from the inter webs and use that as a guide for finding the fault.
Double check the resistance on the new clutch to confirm its a good part
cichy1012
Has thanked: 1 time
Post by cichy1012 »
one more questions. as far as fuses and relays that pertain to this.-- the only fuses and relays for this are in the hood correct by the fire wall? nothing in the glove box or on the side? I know im 1994 940 a solder spot broke off in the panel on the board where the knobs were that needed to be fixed and that got my 94 up but i assuming this is different in the 98's
