2000 S70 Engine, Traction, ABS and Brake light on
Were Read 2 Def
- Year and Model: 2000 S70
I have a 2000 Volvo S70 base model. It has 121,000 miles on it. Just recently the check engine light came on, then ABS, traction control and brakes lights. They all come and go now, but nothing seems to be wrong with the car that I can tell. I read on an older forum that it could be the ABS module. Any suggestions?
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
More than likely, more so if it's intermittent or based on hot/cold. Usually you're just going to get the abs/traction lights intermittently for period of time then light joins in.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
Get those codes read do you can find out exactly what's bring reported
Get the actual P code, not the generic description
p1234 is format
If you to fix Volvos by symptom, budget 1000-1500 for part throwing. Diagnosis saves Dollars.
p1234 is format
