Ever since I replaced the coolant tank(overflow bottle) a year ago, the light has stayed on continuously. I have replaced the level sensor twice(new ones), and the coolant tank once, since then. Light stays on.
With engine running and using a screwdriver to push down on the float in the tank, the light goes off. Release the float and light soon comes on again.
Could this be some kind of electrical problem, and how do I check that?
Thanks.
2000 v70xc coolant level dashboard light.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
You really should figure that out. I would say that it IS an electrical problem.
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
If I'm not mistaken, the light should go ON if you push down... and off when it comes up. You're saying it does the opposite?
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
jenkinskg
- Year and Model: 04 c70 hpt 98 s70 xc
- Has thanked: 1 time
I bought replacement tank, had same problem, looks like magnet was not strong enough in float.
Was going to send it back asap, but did not want to drain and put old one back.
Pulled sensor out of bottom, taped magnet onto sensor, then light is out ever since.
I am running waterless coolant, so not afraid of overheats, may buy another if I feel like it
2004 c70 2.3HPT, s60 2.5T
Has the earth flipped its magnetic poles again? O, Henry!
jenkinskg
Magnet on float hits end of sensor and tells it water is high enough to turn off light.
Just got junk tank, will pull shit brand one with oem and problem will go away.
Next time I will test before install
- 505 Views
- 48707 Views
Last post by ggleavitt
- 12 Replies
- 7150 Views
Last post by RickHaleParker
- 5525 Views
Last post by Cees Klumper
- 4900 Views
Last post by ndphotonl
