IPD sale Volvo Parts
2004 S80 T6 Ice White
Keep track of your Volvo's maintenance here. Keep track of what you did, when, and how much it cost.
Forum rules
June
Year and Model: 2004 S80 T6
Has thanked: 157 times
Been thanked: 76 times
United States of America
Re: 2004 S80 T6 Ice White
Post by June » Mon Aug 08, 2016 7:56 pm
Driving home from Tampa engine light came on and turbos were clearly not operating proper also I felt nervous about the non-Volvo fluid in the transmission so I drove straight to the shop. My mechanic determined vacuum hose to turbos had been damaged when cam seals were being changed. They were brittle from age. Also I opted to have 120k service done early since they were keeping my car. As always Mike had a Volvo waiting for me to drive.
June 16, 2016 114,290 miles
Line 1
120k
6 8889956 Castrol 2.80 total 16.80
18830 Break service kit 29.95
1 977751 gasket 1.00
1 30731808 belt 50.00
1 30630752 pollen filter 29.95
1 8692072 Spark plug kit 48.00
1 9186361 air filter 26.00
Parts 252.70 labor 377.60 total 630.30
Line 2
Replace turbo hoses
1 8642978 nipple 32.85
1 9443862 hose 32.55
Parts 65.40 labor 278.98 total 344.38
Line 3
Synthetic transmission fluid complete flush
1 3124 synthetic atf 110.00
1 6600 BG Trans kit 27.95
Labor 99.00
Parts 137.95 labor 99.00 total 236.95
1 1275810 oil filter 12.00
1 30620512 fuel filter 39.00
Ticket total $1322.07
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
June
Post by June » Mon Aug 08, 2016 8:14 pm
Due to a funeral I had to drive 3,300 miles round trip so I took her in for a early oil change though oil had like 1000 miles since previous service. Plus this was the car's first out of Florida road trip and due to hot summer I had Castrol Edge 10w30 used. I just don't want strange shops touching my car or was I going to run 4000 plus miles on oil. I know they say 7500 is OK and even 10000, but I think that is crazy.
July 14, 2016 115,313 miles
1 530su6 Castrol Edge 10w30 41.80
Labor 22.20
Ticket total $89.81
Also he put 1 quart Edge 10w30 plus a gallon of Volvo coolant in the trunk for me just in case. No extra charge
My Volvo cars owned
1996 960 ordered
June
Post by June » Mon Aug 08, 2016 8:18 pm
August 1, 2016 118,641 miles
Oil change plus tire rotation
1 530su6 Castrol Edge 5w30 43.30
Labor 45.55
Shop charge 9.17
Ticket total $ 118.79
My Volvo cars owned
1996 960 ordered
June
Post by June » Wed Sep 07, 2016 7:22 pm
Took her in to Osteen Volvo for a oil change and to find out what was going on with the blower fan in the dash. Insulation fabric was caught up in the fan.
September 7, 2016
121,344 miles
Line 1
Perform deluxe oil change service with tire rotation.
35 CVR. $45.55
1 1275810 oil filter INS $12.00
1 977751 gasket. $1.00
Total Line A $58.55
Line 2
Synthetic oil upgrade
1 530SU6 $41.80
Line total $41.80
Line 3
AC fan vibrates above low speed.
Caused by insulation inside blower fan.
2 9133417 plastic rivet $8.08
2 1268176 clip $6.00
35 CVR $0.00 wow no labor charge!
Line total $14.08
Ticket totaled $133.46 which is really not bad considering the fan problem!
My Volvo cars owned
1996 960 ordered
June
Post by June » Tue Sep 27, 2016 5:43 pm
After nearly getting side swiped on the interstate this morning the car felt wrong. I took her straight into Osteen Volvo service. It turned out sway bar links were damaged.
September 27, 2016
123,086 miles
CVR $139.49
2 31201602 link $77.88 $155.76
Total 295.25
Shop charge $23.95
Total bill $341.55
My Volvo cars owned
1996 960 ordered
June
Post by June » Mon Nov 14, 2016 10:27 am
October 14, 2016
124,497
I took the car in for a lof, and what I thought was a miss in the engine. Car returned with the same problem.
$117.04
My Volvo cars owned
1996 960 ordered
June
Post by June » Mon Nov 14, 2016 10:37 am
October 21, 2016
124,584
I took the car back in for the vibration like a misfire on acceleration and detail.
Detail $289.24
Vibration was determined to be a engine mount.
$576.01
Shop fee $23.95
Total bill $951.45
My Volvo cars owned
1996 960 ordered
June
Post by June » Tue Nov 15, 2016 2:10 pm
November 16,2016
125,442 miles
I was getting upset because the vibration or misfire was still happening. So I took it to Osteen Volvo for service and this was the ticket. They warrantied both front axles and replace them at no charge to me. Volvo Corporation made good on the forever warranty on parts and labor without any complaint the vibration was thought to be coming from one of the axles. So to be sure Osteen Volvo just replace both under warranty to be sure the problem was solved. This was the third visit with the same complaint so they made sure the car was fixed.
Line 1
Check for vibration or misfire.
1 8251781 Axle shaft. Warranty
1 30640878 semi screw. Warranty
No charge for axle replacement as I replaced both axles back in March.
Line 2
1 8251782 axles shaft warranty
1 30640878 sems screw warranty
No charge this line
Line 3
I had new tires put on Michelin.
CVR 84.95
4 tvalve tire valves 1.25 total 5.00
4 mic41073 225/50/17michprimacy 193.00 total 772.00
4 state tire disposal fee 4.00
4 dealer tire disposal fee 8.00
Line 4
Alignment 4-wheel
84.00
Line 5
Left inner tie rod loose. I requested all tie rods to be replaced at this time to prevent dealing with this in a few thousand miles for another also ball joints were replaced per my request now the front end is fresh. I had the control arms replaced earlier this year.
CVR 418.47
2 274353 steering rod 148.35 total 296.70
2 30761719 ball joint kit 98.36 196.72
1 30761718 ball joint kit 98.36
Parts 591.78 labor 418.47 total 1010.25
Environmental fee 23.9
Total bill $ 2314.42
My Volvo cars owned
1996 960 ordered
June
Post by June » Tue Nov 15, 2016 2:12 pm
November 9, 2016
125,633
Lof full synthetic. 94.71
My Volvo cars owned
1996 960 ordered
June
Post by June » Wed Nov 23, 2016 10:17 pm
I am visiting family for Thanksgiving and on the way here my left front break stuck on. I took it to Ferman Volvo for repair. The car had a bad break line. I was sold new rubber lines, pads, and rotors. The next day they called wanting to sell me a new abs unit. I decided the abs unit as no abs light on and abs and traction control also is working so why replace a $2200.00 unit? I was told break power bleeder would not work so manual bleeding would be tried. Breaks are working fine and I mashed the pedal with both feet at 75mph, abs worked perfectly and stopped straight. Here is the bill
11/23/2016
126805 miles
Line 3
31257705-9 break hose [email protected] 156.90
Labor 130.00
Total 286.90
Line 4
31400740-2 break disc kit [email protected] 249.12
8634921-4 pad kit 111.33
81229407 plastilube 3.95
Labor 260.00
Line 5
BG dot 4 break service 129.95
Labor discount 97.65
Total bill 891.31
My Volvo cars owned
1996 960 ordered
Who is online
Users browsing this forum: No registered users and 1 guest
