IPD sale Volvo Parts
2004 S80 T6 Ice White
Keep track of your Volvo's maintenance here. Keep track of what you did, when, and how much it cost.
Forum rules
June
Year and Model: 2004 S80 T6
Has thanked: 164 times
Been thanked: 83 times
United States of America
Re: 2004 S80 T6 Ice White
Post by June » Sat Oct 21, 2017 4:29 pm
June wrote:
Mon Aug 08, 2016 4:12 pm
April 27, 2016
Took in for new moonroof side pieces and a/c blowing slow.
Needed filter
1 708 Frigie-fresh 8.98
1 3060752 pollen filter
Labor 64.75
Line 2
2 8643242 Modesty Panel 28.89 total 57.78
Total bill $188.29
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
June
Post by June » Sat Oct 21, 2017 4:31 pm
June wrote:
Mon Aug 08, 2016 4:24 pm
May 3, 2016 111,875
After endless battle with Volvo over the On Call which has been not supported forever, really upsetting me. Much worse has been the endless messages on dash to renew subscription. Yes Volvo sold me a option that they should have upgraded the equipment in my opinion, but I finally got someone at Volvo USA to send my dealer info to stop messages. I argued forever over this problem.
Line 1
Remove On Call
1 8651312 VOC Remove 30.22
Labor 64.75
Line 2
Battery died in mechanic stall
1 30772231 Battery 217.85
Disposal fee 1.50
Labor 70.00
Total bill $369.34
My Volvo cars owned
1996 960 ordered
June
Post by June » Sat Oct 21, 2017 4:34 pm
June wrote:
Mon Aug 08, 2016 4:32 pm
May 31, 2016 113,487
Car started making a click noise shifting from reverse to drive.
Line 1
Repair axle ping remove and loctite both axles
Labor 139.49
Shop charge 12.55
Total $162.68
Before leaving I thought about the windshield wiper needed replacement
1 31301437 Wiper Bl 1018D 65.75
Total $61.17
My Volvo cars owned
1996 960 ordered
June
Post by June » Sat Oct 21, 2017 4:37 pm
June wrote:
Mon Aug 08, 2016 7:56 pm
Driving home from Tampa engine light came on and turbos were clearly not operating proper also I felt nervous about the non-Volvo fluid in the transmission so I drove straight to the shop. My mechanic determined vacuum hose to turbos had been damaged when cam seals were being changed. They were brittle from age. Also I opted to have 120k service done early since they were keeping my car. As always Mike had a Volvo waiting for me to drive.
June 16, 2016 114,290 miles
Line 1
120k
6 8889956 Castrol 2.80 total 16.80
18830 Break service kit 29.95
1 977751 gasket 1.00
1 30731808 belt 50.00
1 30630752 pollen filter 29.95
1 8692072 Spark plug kit 48.00
1 9186361 air filter 26.00
Parts 252.70 labor 377.60 total 630.30
Line 2
Replace turbo hoses
1 8642978 nipple 32.85
1 9443862 hose 32.55
Parts 65.40 labor 278.98 total 344.38
Line 3
Synthetic transmission fluid complete flush
1 3124 synthetic atf 110.00
1 6600 BG Trans kit 27.95
Labor 99.00
Parts 137.95 labor 99.00 total 236.95
1 1275810 oil filter 12.00
1 30620512 fuel filter 39.00
Ticket total $1322.07
My Volvo cars owned
1996 960 ordered
June
Post by June » Sat Oct 21, 2017 4:39 pm
June wrote:
Mon Aug 08, 2016 8:14 pm
Due to a funeral I had to drive 3,300 miles round trip so I took her in for a early oil change though oil had like 1000 miles since previous service. Plus this was the car's first out of Florida road trip and due to hot summer I had Castrol Edge 10w30 used. I just don't want strange shops touching my car or was I going to run 4000 plus miles on oil. I know they say 7500 is OK and even 10000, but I think that is crazy.
July 14, 2016 115,313 miles
1 530su6 Castrol Edge 10w30 41.80
Labor 22.20
Ticket total $89.81
Also he put 1 quart Edge 10w30 plus a gallon of Volvo coolant in the trunk for me just in case. No extra charge
My Volvo cars owned
1996 960 ordered
June
Post by June » Sat Oct 21, 2017 5:52 pm
June wrote:
Wed Sep 07, 2016 7:22 pm
Took her in to Osteen Volvo for a oil change and to find out what was going on with the blower fan in the dash. Insulation fabric was caught up in the fan.
September 7, 2016
121,344 miles
Line 1
Perform deluxe oil change service with tire rotation.
35 CVR. $45.55
1 1275810 oil filter INS $12.00
1 977751 gasket. $1.00
Total Line A $58.55
Line 2
Synthetic oil upgrade
1 530SU6 $41.80
Line total $41.80
Line 3
AC fan vibrates above low speed.
Caused by insulation inside blower fan.
2 9133417 plastic rivet $8.08
2 1268176 clip $6.00
35 CVR $0.00 wow no labor charge!
Line total $14.08
Ticket totaled $133.46 which is really not bad considering the fan problem!
My Volvo cars owned
1996 960 ordered
June
Post by June » Sat Oct 21, 2017 5:54 pm
June wrote:
Tue Sep 27, 2016 5:43 pm
After nearly getting side swiped on the interstate this morning the car felt wrong. I took her straight into Osteen Volvo service. It turned out sway bar links were damaged.
September 27, 2016
123,086 miles
CVR $139.49
2 31201602 link $77.88 $155.76
Total 295.25
Shop charge $23.95
Total bill $341.55
My Volvo cars owned
1996 960 ordered
June
Post by June » Sat Oct 21, 2017 5:57 pm
June wrote:
Sat Mar 18, 2017 5:29 pm
3/17/17 134,067
I took her to Osteen Volvo with a clunk going into reverse after driving in drive, I also wanted new struts, springs, and related parts, and replace the starter cable.
Mechanic discovered the steering rack causing pop sound and main engine mount had play as well. I highly recommend replacing struts, springs, and related parts. The car drives like I remember it did around corners, over bumps, just night and day difference, also the front is a good inch and a half higher now. Wow am I pleased worth the $5100.00 price tag.
Steering gear has excessive play
1 36050286 steering gear $1382.29
1 30741950 steering shaft 97.32
1 969092 o ring 4.32
1 98120 o ring 11.38
Fluid 33.05
1 9461483 engine pad (mount) 186.31
1 9461483 stabilizer bar 217.14
Labor 1046.18
Parts 1931.81 Labor 1046.18 total $2977.99
Line 2
Replace struts and springs
2 8667253 shock absorber. $500.16
2 30683637 spring seat 122.40
2 9489363 spring 126.04
2 31201396 stop washer 26.72
2 31212191 roller 60.48
Labor 418.47
Parts 835.80 labor 418.47 total 1254.27
Line 3
Replace starter B+cable and lower part of engine compartment fuse box
1 9469762 battery cable $123.62
1 9494210 box
Labor 348.73
Parts 178.94 labor 348.73 total 527.67
Environmental fee 23.95
Total ticket
Parts 2946.55
Labor 1813.38
Environment fee 23.95
Total 4783.88
Tax 334.87
Total repair $5118.75
My Volvo cars owned
1996 960 ordered
June
Post by June » Sat Oct 21, 2017 5:59 pm
June wrote:
Mon Nov 14, 2016 10:27 am
October 14, 2016
124,497
I took the car in for a lof, and what I thought was a miss in the engine. Car returned with the same problem.
$117.04
My Volvo cars owned
1996 960 ordered
June
Post by June » Sat Oct 21, 2017 6:02 pm
June wrote:
Tue Nov 15, 2016 2:10 pm
November 16,2016
125,442 miles
I was getting upset because the vibration or misfire was still happening. So I took it to Osteen Volvo for service and this was the ticket. They warrantied both front axles and replace them at no charge to me. Volvo Corporation made good on the forever warranty on parts and labor without any complaint the vibration was thought to be coming from one of the axles. So to be sure Osteen Volvo just replace both under warranty to be sure the problem was solved. This was the third visit with the same complaint so they made sure the car was fixed.
Line 1
Check for vibration or misfire.
1 8251781 Axle shaft. Warranty
1 30640878 semi screw. Warranty
No charge for axle replacement as I replaced both axles back in March.
Line 2
1 8251782 axles shaft warranty
1 30640878 sems screw warranty
No charge this line
Line 3
I had new tires put on Michelin.
CVR 84.95
4 tvalve tire valves 1.25 total 5.00
4 mic41073 225/50/17michprimacy 193.00 total 772.00
4 state tire disposal fee 4.00
4 dealer tire disposal fee 8.00
Line 4
Alignment 4-wheel
84.00
Line 5
Left inner tie rod loose. I requested all tie rods to be replaced at this time to prevent dealing with this in a few thousand miles for another also ball joints were replaced per my request now the front end is fresh. I had the control arms replaced earlier this year.
CVR 418.47
2 274353 steering rod 148.35 total 296.70
2 30761719 ball joint kit 98.36 196.72
1 30761718 ball joint kit 98.36
Parts 591.78 labor 418.47 total 1010.25
Total bill $ 2314.42
My Volvo cars owned
1996 960 ordered
Who is online
Users browsing this forum: No registered users and 0 guests
