Starting issue (Bad aftermarket MAF) new Bosch MAF worked Topic is solved
ChadLee
- Year and Model: 1998 V70
- Has thanked: 6 times
About six months ago my 98 v70 would choke and sputter like it was running bad fuel. If I kept the RPM's up it would work through the problem and be ok. If my RPM's dropped below 1200, the car would die and not restart right away without a small miracle. I am not a mechanic but thought I would try and help myself and tackle a few things. I replaced the MAF, O2 sensor, cleaned the throttle body, spark plugs, wires, thermostat, coolant temperature sensor, pcv system and fuel pump relay (tested-used). The original problem seems to have either retreated or been resolved. Now, the car stars perfect every morning, every subsequent start required keeping the ignition engaged. It seems like something misses on the first try and then it fires up. I am not pressing the gas pedal. Starter solenoid? Fuel pump? Fuel filter? Injectors? Distributor? Low tire pressure? User error? Any help would be greatly appreciated. Thank you.
1986 245 DL, 1989 244, 745 Turbo and 1981 245 DL - gone to new homes
1989 245 GL - Wife's daily driver
1989 245 DL - In the works for a daily
1998 V70 - Daily driver
2001 V70 - Next project
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
Codes! Read codes! Throwing parts at these cars in the dark gets very expensive, extremely fast. Did I mention that you need to read your codes?
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
ChadLee
The only code I get is the air blower motor.
Sommerfeldt
Then it could be your henway. But start by seeing if your problem gets better or worse by disconnecting the MAF - are you sure there are no vacuum leaks?
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
"Henway?" -- a few pounds. Rimshot. Try the veal. Don't forget to tip your waitress, I'm here through Thursday. . .
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Been thanked: 4064 times
1 kilogram
You've been MVSuckerpunched
ChadLee
First start of the day.....no problem
Any start after.......problem
Get a fuel pressure gauge and watch the pressure at the rail.
Cheaper way , when you get the hard start, give it a 2 second shot of starter fluid into the manifold to see if it then fires
You are trying to isolate fuel from ignition problems on the diagnostic tree.
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
Did you check out your fuel filter?
Retired:
2015 Volvo S60, T5, 85K
ChadLee
Starter fluid downstream from the maf?
I am picking up a fuel filter and replacing it this afternoon. I tackled this job on a 89 740 and it was a pain in the neck, looks to be easier on this car.
I will report tomorrow.
- 3093 Views
Last post by itsmekirby
- 943 Views
Last post by Craigd2599
- 1798 Views
Last post by rspi
- 806 Views
Last post by Clemens
- 21 Replies
- 6719 Views
