I have a 98 S70 with 188k miles. As expected, the drip molding along the roof is looking terrible. Rather than spending $150 to replace each one, I'm thinking they can be refurbished slightly.
The drip molding consists of a metal center section (coated in some rubber-ish material) and then rubber seals/trim on both sides of the metal center.
On the driver's side, the rubber coating is gone and most of the rubber seals too, so I can actually see into the channel. The passenger side is in better shape, but it's on its way out.
Has anyone removed the rubber seals/strips and just left the metal center section? This kind of defies the point of having the trim at all. But its the cheapest solution. Would be nice to see some pics of this.
Is this a safe long-term solution? Would water getting into the channel cause any significant damage?
1998 S70 - Drip/Roof Molding Falling Apart
ferocity02
- Been thanked: 14 times
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
I've read about black out tape as an option and was considering doing that myself when I found a good set in a scrap yard.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
ferocity02
I've read about that too, but isn't that just to cover the metal piece? I was planning on painting it. Easy enough once it's off the car.E Showell wrote:I've read about black out tape as an option and was considering doing that myself when I found a good set in a scrap yard.
The issue is that the rubber seals attached to the metal piece are pretty much gone. So I'm curious if it's okay to remove the rubber seals completely, leaving just the metal center section.
If I need to keep the rubber pieces then I'll need to find an entire trim piece from a junkyard or buy a new one. The local dealer agreed on $135 for a new one.
- E Showell
I don't know, but I think the black-out tape approach involves wrapping down to and slightly overlapping the rubber on the bottom.
'95 855 auto (sold)
'95 855 auto (sold)
- 15 Replies
- 2259 Views
Last post by pobracara
- 13 Replies
- 3032 Views
Last post by imaV70Rdriver
- 1253 Views
Last post by CorpsOfficer
- 1390 Views
Last post by volvolugnut
- 339 Views
Last post by filmmakersue
