Sometimes it starts right up, but usually I have to crank and crank then it may or may not start.
I does turn over, but acts like and old car with choke problems or out of fuel. It's a turbo, automatic with 136000 miles.
Here is what I have replaced:
Fuel pressure regulator
Idle air control valve (IAC)
coil packs (volvo oem)
ignition wires (volvo oem)
spark plugs (volvo oem)
cleaned throttle body
fuel injectors, all four
o2 sensors (both)
Any help would be greatly appreciated. Thanks
2002 s40 intermittently won't start, tried everything!
difflock54
- Year and Model: V40 Nordic 2002
- Has thanked: 7 times
- Been thanked: 2 times
May be the MAF sensor?
Unplug it and see if there is any improvement in starting and engine running whilst disconnected.
davidtalbert
- Year and Model: 2002 s40
Thanks, I will try this today and let you know.
davidtalbert
I unplugged it and tried to start, cranks but no start. Plugged it back in, same thing no start.
- alschnertz
- Year and Model: 1995 854T
- Has thanked: 2 times
- Been thanked: 12 times
Try "cleaning" the PNP switch contacts by rowing the gearshift back and forth 20 times - WITH THE ENGINE OFF.
Since it's turning over I'm doubtful, but it won't hurt.
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
- alschnertz
Did you ever check the fuel pressure with a gauge?
It should be around 44 psi.
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
davidtalbert
No I haven't checked fuel pressure. I will have to get a gauge and check it. Are you saying it should be 44 psi with the key turned on? Not cranking it over...
difflock54
Check around the engine bay for any loose,damaged or disconnected vacuum hoses.
One may have been acciddently disturbed when you were replacing one of the components on your list above.
Given you have replaced the fuel pressure regulator one wonders if the problem could be the fuel pump or even the fuel filter.
How does the air filter look? Clean or dirty?
davidtalbert
I will check these things.. Thanks for your suggestions!
- alschnertz
IIRC, it should be around 44 psi at all times whenever the pump is running.davidtalbert wrote:Are you saying it should be 44 psi with the key turned on? Not cranking it over...
Regardless, I would check...
1. Key on, not running;
2. While cranking;
3. While running.
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
- 16 Replies
- 3608 Views
Last post by MadeInJapan
- 950 Views
Last post by rice240
- 15 Replies
- 5128 Views
Last post by cocoli
- 13 Replies
- 1928 Views
Last post by 122sPhil
- 13 Replies
- 5048 Views
Last post by SuperHerman
