The blower sometimes would kick in but usually doesn't, with the ECC lights flashing a few times. I pulled the blower motor and lubricated it, watched it spin a bit before reinstalling it. But then nothing. Pulled pulled it back out and checked voltage at its terminals. Nothing. I also pulled the resistor and checked its voltage at each terminal lead for both the four small wires and the two large ones. Nothing. Fuses are good.
Perhaps I do not have a good ground for the meter. What is a good grounding location in the passenger compartment? I tried the bolt that holds the seats in place.
If there is no voltage coming to the resistor, where would I look to find the fault?
What other things might I check. Chilton's doesn't include these circuits in the pertinent manual.
Blower not working
- Year and Model: Many Volvos
- Been thanked: 76 times
If you get no voltage at the connector with the large wires then the fuse is bad. There are two fuses for the climate unit, check both of them. If you ground the blue wire the blower should come on at full speed, even with the key off. The bolt at the seat should be a suitable ground.
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
Check Volvowiringdiagrams for your 850.
M1 10W-30 HM
M1 10W-30 HM
- Has thanked: 1611 times
- Been thanked: 4075 times
The wiring diagrams are On the internet but we do not host them here by a mutual agreement with Volvo/MVS.
- Has thanked: 312 times
- Been thanked: 818 times
What sleddriver said (http://www.volvowiringdiagrams.com/).
- 1277 Views
Last post by Ozark Lee
- 2504 Views
Last post by WA-Boater
- 427 Views
Last post by alschnertz
- 1454 Views
Last post by jreed
- 684 Views
Last post by erikv11
