Hello,
I've recently bought a 2006 C70 with a 5 speed manual gearbox. It has a rather annoying issue whereby when you engage reverse and lift the clutch it either tries to creep forward as if it thinks it is in 4th, or makes a whizzing/ grinding noise as if the gear is not properly selected. If you stir the box a couple of time it gets there eventually.
The cables are in the right place on the top of the box and are not being obstructed by the battery cables.
Any thoughts gratefully received.
Best Regards
Richard
2006 C70 reverse gear
- Has thanked: 17 times
- Been thanked: 35 times
You might try draining and refilling the gear oil. It's not outrageous and you can do it yourself fairly easily. I would definitely buy the correct fluid. Check on http://www.fcpeuro.com I believe they also have a video on how to do this. How many miles on her?
Different car but same symptoms? You might check this thread out as well: https://www.matthewsvolvosite.com/forums ... =9&t=49287
- 2497 Views
Last post by MDK
- 11 Replies
- 2522 Views
Last post by 4sdAIR
- 1531 Views
Last post by s80volvo2004
- 1505 Views
Last post by matthew1
- 2663 Views
