850 not getting fire from distributer to plug wires.
Derbyrunner
- Year and Model: 1998 S70
Alright trying to help a friend out with his 95 850 glt. Changed coil out and still not getting fire to plug wires. Distributer is not cracked. Could faulty TCU or ECU cause this issue?
- Has thanked: 311 times
- Been thanked: 817 times
Is the coil making spark, but its not getting out of the cap? That would point to the rotor.
If you mean no spark at the coil, I would suspect the cam position sensor (more common) or the crank sensor (less common).
Derbyrunner
Coil is making a spark but that's where it ends.
- Has thanked: 316 times
- Been thanked: 531 times
Rule #1 of diagnosing issues with your Volvo: it is not your ECU, ECM, or computer. (Hope you don't mind me quoting you, abscate!)
Might be the rotor.
Might be the rotor.
- 11 Replies
- 6117 Views
Last post by xanthefin
- 245 Views
- 12 Replies
- 3043 Views
Last post by kippster41493
- 719 Views
Last post by rspi
- 13 Replies
- 2682 Views
Last post by wizechatmgr
