1995 volvo 850 no spark
Joshroark1998
- Year and Model: 1995 850
Ok I just bought a car and im not getting any spark from the rotor button to the points for the plug wires but I am getting it to the cap and through the cap I have changed the cap and button twice
- Has thanked: 311 times
- Been thanked: 817 times
Sorry but I'm not getting it - where is there spark and where is there not spark?
If spark is getting through the rotor but not through the wires, then clearly the wires are bad. Every one of them, which seems unlikely. But how would you even see this, did you pull each wire at the cap, and detect spark where the wire plugs in to the cap?
Joshroark1998
Spark is not coming through the button to the marks to go to the plug wires but it is coming through the cap
Gets through the cap to the rotor, but doesn't get through the rotor? That would have to be a bad rotor, there is no other possibility. Is everything OK inside the cap, like the dust cap is positioned properly? Could it be you have the wrong parts?
The rotor has electronics inside it, that can go bad. If you have tried a couple rotors then maybe they are getting cooked? Strange.
Joshroark1998
Would the coil be putting to much power to the button
Yes that's what I mean. But I don't see how unless it's the wrong coil, even then it seems unlikely, they just put out 12V.
Oh, are you sure the plug wires are on in the correct order? Some of the sources show the wrong order.
This is correct: http://volvospeed.com/volvo_repairs_how ... plugs.html
EDIT: ehhh that wouldn't mean no spark, just spark at the wrong time so not starting.
Joshroark1998
Well when I bought the car it didnt have a instrument cluster so I crossed the wire at the instrument cluster do you think it is supposed to cut some power back
- 3025 Views
Last post by Roger_850T
- 3295 Views
Last post by ndphotonl
- 1938 Views
- 26 Replies
- 4383 Views
Last post by momentumbob
- 588 Views
Last post by dtmmoore2
